Old 01-19-2009, 08:13 PM
Keefla Keefla is offline
rca whining noise/no power up
hey all,
a co-worker of mine knows how ive had luck fixing my sylvania from you guys. he asked me about his tv. its an rca f32650, chassis number atc113ca1. he said it shut down and the power light started flashing, by the time i saw it when he plugged it in all it would do it whine really high pitched, no power light, nothing. he was told the flybacks on 'those' go bad a lot, but he didnt post on this forum so i dont really know. any ideas? its a 32" i believe, a lot of inputs. probably nothing facny really but id like to be able to help him out. whuddya think.
Old 01-19-2009, 08:21 PM
zenith2134's Avatar
If the flyback is bad, which it very well might be on this set, the horizontal output is probably toast as well. Now to figure out why they failed. Leave that to the experts....
Old 01-19-2009, 09:25 PM
magmod93 magmod93 is offline
Banned
As an "expert" service tech, I'd say the flyback/horiz output transistor is bad. Also check the 2 big power diodes for shorts in the power supply. They're mounted side by side on ferret tubes next to the switchmode transformer, and fry anytime the fly goes. And also check the solder connections very closely on the small coil next to the horizontal output transistor. They're prone to have bad joints.
Old 01-19-2009, 10:10 PM
thanks for the input guys, ill crack into it hopefully wednesday after work and let you know what i find. Ill probably need help with part numbers etc on the flyback and transistor etc. Ill most likely just order all the parts you listed and shotgun the replacement. Still open to other input thow to if anyone has other suggestions let'em rip.
Old 01-19-2009, 11:10 PM
I'll second that the flyback went belly up and took the horizontal output transistor with it. A word of caution. Don't power the set up in it's current state. The power supplies in those won't take a short on the B+ line for long without blowing up. No need to have to rebuild the P/S if you don't have to. Before you do anything, unsolder the HOT and check it for shorts. The HOT is the big black transistor that's mounted to a heatsink behind the flyback. You should be able to get the parts from www.tritronicsinc.com.
Old 01-20-2009, 12:55 AM
Banned
That's why I stated to check the power supply diode for the 135V B+ line... the set is whining most likely because it's now shorted. It's in shutdown...I've replaced hundreds of them already... trust me, I know.
Old 01-20-2009, 12:21 PM
rcaman's Avatar
rcaman rcaman is offline
flyback part # 257805 horiz. output is 237470 usr hr diemen flyback or rca oem not asti generic. steve
Old 01-20-2009, 01:36 PM
steve, any thoughts on part numbers for the diodes? the site lists 2 seperate part numbers under diode. they have the rca HOT and flyback thow so im good.
Old 01-21-2009, 09:35 AM
rcaman's Avatar
im not at work to look the numbers up. but i have never had to replace those diodes just the fly and hot. steve
Old 01-21-2009, 09:42 PM
tested the HOT, yep, shorted all the way across. so i ordered that and a fly. a few days it all should be in. like 80 or so total cost. hopefully will have good news to report. thanks again guys you are really an impressive group of techs.
Old 01-22-2009, 02:22 AM
Banned
Heh, when you've repaired tens of thousands of tv sets for customers over decades, you just KNOW things.......LOL
Old 01-26-2009, 11:06 PM
Got the parts in today, flyback and HOT. got out the gun, solder wick and had a go at it. it was maybe 20 minutes worth of work since the set was already apart from testing the HOT. put it back togeather and tried her out. first good sign was no whining when i plugged it in, hit the power button and it clicked on and a few seconds later i got a picture! fiddled with the screen and focus controlls with a pen cap (only plastic tool i could quickly fashon). there was a tech note with the fly saying that sometimes there will be some issues with the picture tearing on the right side and to add a cap but it looks perfect to me so i put it all back togeather and ran it for about 30 minutes. called John the owner and said he can come by and get it tomorrow, his goal was to have it back by the superbowl....mission accomplished. it was 87 dollars in parts after shipping. i of course didnt charge him to do it since you guys did all the real work....all i did is replace parts. but thak you steve for the help, and to magmod, who appears banned already, and radiotvnut for the site where i got the parts from (good site!). You guys are awesome, and John really thanks you all also.
