Old 12-13-2008, 09:47 PM
fsjonsey's Avatar
fsjonsey fsjonsey is offline
Living The Draper Ethos
80's Toshiba with Intermittant Audio
My grandmother gave me her late 80's bedroom set, a 20" Toshiba to fix. It has an audio issue that starts after the set has had a few minutes to warm up. The audio either cuts out or gets very quiet every few minutes, and a slap to the side of the case brings it back. I figured it would be cold solder joints on the PCB. Would resoldering any cold joints on the audio section take care of it?
This device isn't a spaceship, it's a time machine. It goes backwards, and forwards... it takes us to a place where we ache to go again.
Old 12-13-2008, 10:04 PM
MRX37 MRX37 is offline
I don't know, but from working on a few 80's Toshiba's I recommend replacing every red/brown colored electrolytic cap you can find, especally in the vertical circuit.
Old 12-13-2008, 10:08 PM
Findm-Keepm's Avatar
Followin' the Rules...
With no model number, I pulled up all Toshiba Audio gripes. Here's what I have:
Cheers,
Brian
USN RET 22YRS (Avionics/Cal)
Old 12-13-2008, 10:18 PM
fsjonsey's Avatar
Cheers,
Sorry for not posting the Model Number, It's a CE909.
Thanks for the troubleshooting page. It's symptoms are exactly the same as the fourth description on that page. Looks like I have some soldering to do.
Old 12-14-2008, 12:42 PM
kx250rider's Avatar
REAL TVs have TUBES!
I can't remember all the model numbers, but look to see if the main TV chip is a TA-7777 (and a suffix letter or two). If so, carefully solder all of the pins on that chip. I've seen that many many times in the early & mid-80s Toshibas.
Charles
