Old 11-24-2008, 01:10 AM
MRX37 MRX37 is offline
Changed my first filter cap.
I had been wanting to replace the 680uf 200 volt cap in my 1991 RCA Colortrak 2000 since I found it. The HV regulation was okayish, but could have been better.
As luck would have it, someone gave me an RCA colortrak from 2001. I found out that the chassis board had old pancake syrup all over it, so I junked it. Before I threw it out however, I saw that it had a 680uf 200 volt filter cap...
So I replaced a 17 year old filter cap with a 7 year old filter cap.
The results are encouraging. HV regulation seems to be improved. For some reason I had to readjust the G2 and focus controls as they were a bit off. I assume the newer cap changed the HV a little bit.
Old 11-24-2008, 01:25 AM
There should be another cap in the B+ line. It's rated somewhere between 47 uf and 100 uf @ 160 volts. You might want to change that one while you're at it.
Old 11-24-2008, 01:27 AM
You mean a 33uf 180 volt light blue Nichicon cap? Changed that too.
Old 11-24-2008, 01:32 AM
Yes, come to think of it.
Old 11-24-2008, 02:02 AM
I wasn't going to change it, but I pulled the newer one off the syrup coated chassis, cleaned it up, and tested them both. The newer one had a slightly higher reading (~1uf higher) so, I put that one in. The newer one is also rated for 200 volts.
Old 11-24-2008, 02:21 AM
karmaman's Avatar
karmaman karmaman is offline
AK Member
Did the new filter cap help at all with the black streaks when there was white text on a black background?
Methinks a full recap would greatly improve PQ on older TV's no?
Old 11-24-2008, 11:39 AM
Um, if it helped, it helped slightly. The streaks are still there.
Eventually I'm probably going to shotgun all the caps in the video section, but I want to be sure I replace them with new caps that won't fail inside of three years.
PS: The streaking also happens with black text on an orange background. Makes the area to the left and to the right look like a darker orange.
Old 11-24-2008, 11:55 AM
zenith2134's Avatar
Passed up an 89 Colortrak with video inputs last night trashpickin.
Old 11-24-2008, 03:36 PM
Shoulda grabbed it. Might have had a good CRT in it.
Old 11-25-2008, 12:22 AM
karmaman's Avatar
AK Member
MRX, if you start shotgunning caps make sure you replace them with Nichicon, Nippon/United Chemicon, Rubycon, Sanyo, or Panasonic/Matsushita. Personally I'd go with Rubycon or Matsushita, those two are tops.
I frequent badcaps.net a lot, that's where I get all my info.
Old 11-25-2008, 12:43 AM
I've had a few Rubycons go bad on me...
I'd rather go with all Nichicons if I could.
Old 11-25-2008, 02:05 AM
I've seen some of the Rubycon's fail and leak in these early '90's RCA's. I've got a '90 CTC169 chassis that has already had leaking electrolytics replaced and wires jumped across the foil that was eaten away. Now, there are more leaking caps that I've got to deal with.
Old 11-25-2008, 12:53 PM
karmaman's Avatar
AK Member
Really?
That would explain the Rubycon that dried out and made my JVC sound like an electric motor.
Well in any case stick to Japanese manufacturers. There's somewhat of a capacitor epidemic going on right now, everyone seems to be using crap especially in LCD monitors.
Old 11-25-2008, 06:34 PM
Really?
Believe me. I know.
I'm tempted to use the caps from a 2004 JVC chassis I have. The chassis itself is fine. It's just that the CRT was shot. However, I'm unsure of the quality of the caps. they're fine now, but they're only a few years old.
Old 11-29-2008, 09:45 PM
What do you guys think of Lelon caps? That 2004 JVC board has mostly Lelon caps on it. Are they good caps, or junk?
EDIT: according to Google, I'd be a fool to use Lelon caps. Found a few too many horror stories.
