Sanyo TV ID
The year is around late 1974 or early 1975 and it should be solid state IIRC.
I put my hand on the Sams tonight, believe it or not, its a hybrid with 9 tubes. Might be an extra copy around here if you need it, maybe.
Bryan |
Glad someone had the sams on it, I was going by memory and they say that's the first thing to go!
Sounds like a good deal then for the 15.00, grab it up! |
change all the lytics on that top board.
just did a craig with the same chassis for a customer. heat buildup kills the caps. mostly vertical issues but the marginal width till warm was cured too.
i collect and restore vintage radio's,tv's,and ham gear. email for more info |
