Old 10-26-2008, 10:02 AM
shrinkboy's Avatar
shrinkboy shrinkboy is offline
AK Member
Location: Oak Cliff, Texas, just across the Trinity River from Big D
best indoor antennae?
i just picked up a Digital Stream digital video tuner from RS for the CRT unit in the garage. i discovered that i also need an antenna. i had hoped that hooking to the former cable feed would be enough of an 'antenna', but it ain't finding nuthin'. what have you guys found is the best indoor antenna? seems like there is a wide variety of opinion out there....
Technics SL1700/SL1400
Marantz CDR700/Entech205.3
Onkyo TA-RW 311
TEAC x2000r/Realistic TR3000
DBX CX-2/Phase Linear 400 Mk.II
Acoustic Research AR3a
Old 10-26-2008, 06:15 PM
If that cable feed was your local friendly CATV service, they use a different DTV transmission standard than that used for over-the-air DTV broadcasters. So it's not surprising that it didn't find nuthin.
Over the air DTV tends to work better if you have a directional antenna, indoors that's feasible only for UHF. Otherwise, for VHF DTV, you may need a rooftop antenna, as indoor antennas would just be the same as old fashioned rabbit ears (but DTV tends to be fussy to receive with such).
Old 10-26-2008, 06:25 PM
Snade's Avatar
Snade Snade is offline
humble AK member
This is the famous DIY antenna (coat hangers and a piece of wood) for reception of digital tv stations.
http://www.audiokarma.org/forums/sho...7&postcount=13
I use it for an old Trinitron in my garage and it works great. I get about 25 digital stations and I'm 30 miles west of Chicago. I put about 10 feet of coax cable between the antenna and the digital conversion box so I can set the antenna outside the front garage door during the summer when I have the door open, but it works very well inside, too.
By the way, those indoor antennas they now sell that sit on the TV and you plug them in, the reception on these is terrible, the DIY antenna above works way better.
Cheers, Snade
Old 10-26-2008, 06:44 PM
ccheath's Avatar
ccheath ccheath is offline
Got an Idea!
Cheers, Snade
Excellent!!!! You just helped me with my decision on finding a "GOOD" digital antenna in preparation for next year.
CONCEPT 3.5, 4.5, FISHER 201, 400, 500c, HARMAN KARDON 730, 3480, KENWOOD KR-6050, 9400, MARANTZ 2015, 2235B, PIONEER TX-606, SA-7700, SX-434, 737, 780, 980, 1000TW, 1010, 1250, REALISTIC STA-870, SANSUI 5000A, G-7000, 5900Z, SHERWOOD S-6020 CP, S-6040 CP, YAMAHA CR-1020
Old 10-27-2008, 06:59 AM
shrinkboy's Avatar
AK Member
ah, the riches to be found in that shining virtual city on the hill--AK!! i will proceed forthwith to create snade's/pmsummers' hand made version.
snade-- i compliment you on your choice of olympic events to grab a screen shot of-- olympic swimming this summer was mind bending
Onkyo TA-RW 311
Old 10-27-2008, 08:11 PM
kbmuri's Avatar
kbmuri kbmuri is offline
Read this post (if you missed it):
http://www.audiokarma.org/forums/sho...=170137&page=2
before you proceed forthwith...
A reflector adds enough value to be worth the extra time.
Do not attempt to adjust your set.
Old 10-27-2008, 10:07 PM
peverett peverett is offline
I am not using the best antenna(amplified rabbit ears), but these work fine (in good weather) as I am only 30 miles from the transmitter. I am sure that the directional antenna mentioned below would work better at longer distances.
However, I have found that if something metal(like my shop garage type door)is between the transmitter and receiver, this can cause pretty good reception issues. I have no reason to expect this would not to be the case. This would indicate that if you live in a building with a metal frame, you may have issues. For some reason, analog NTSC does not seem to have this issue at a distance of 30 miles-possibly due to the present difference in transmitted power levels.
