Old 06-29-2008, 04:41 PM
dtuomi's Avatar
dtuomi dtuomi is offline
Home NTSC Transmitter
I know this subject has been brought up before, but for some reason I can't find it in while searching the site. Does anyone know if anyone makes low power NTSC transmitters for home use? All I want to do is to transmit from upstairs to downstairs on an unused normal TV channel at very low power.
David
Old 06-29-2008, 07:48 PM
kbmuri's Avatar
kbmuri kbmuri is offline
This adequately does room-to-room UHF:
http://www.audiokarma.org/forums/sho...08#post1925308
The apartment amp discussed a few posts later could be made to do VHF.
This had limited success, your mileage may vary:
http://www.audiokarma.org/forums/sho...ghlight=Ramsey
Do not attempt to adjust your set.
Old 06-29-2008, 07:54 PM
Carmine's Avatar
Carmine Carmine is offline
...enjoys spaghetti.
Easier to build than that (and without any FCC worries) would be a device that converts ATSC to NTSC and can re-transmit them via 75ohm cable.
All of my sets are hard-wired to my outdoor antenna. The antenna comes into the basement and then gets split to about 5 different locations. It would be nice to simply add a converter which would constantly be putting out about the 15-or-so ATSC signals we have, plus the worthwhile digital side channels on unused dial space. (Currently, that's just RTN, lol)
I even drew this diagram for an electronically inclined friend at work and told him to build it for me!
From Captain Video, 1/4/2007
Old 06-29-2008, 08:03 PM
Findm-Keepm's Avatar
Followin' the Rules...
I built my own, albeit constrained to channel 3 or 4. Basically, it's an RF modulator capacitively coupled to a 2-Meter amp. Not sure of the output, but rabbit ears produce a clean picture on the set. Ramsey kits makes a 2 meter amp - the RF modulator is an early Astec (snipped from a junk VIC-20 computer) Modulator and amp are powered by a 6V wall wart.
Aw hell, for 40 bucks, you too can build your own:
http://www.ramseyelectronics.com/cgi...ction&key=TV6C
Cheers,
Brian
USN RET 22YRS (Avionics/Cal)
Old 06-30-2008, 12:25 AM
Dave A's Avatar
Dave A Dave A is offline
Another Ramsey
Ramsey also shows this little...very little...module. It is capable of RF to cable channel 59 with audio/video.
http://www.ramseyelectronics.com/cgi...tion&key=C2000
A grand 20mw. They have a higher power 100mw unit...video only. Would this transmit to an antenna and then to a cable ready VHS (which I save for the tuner) in the cable mode? I would feed it with a dedicated converter box.
I have visions of it in front of a tabletop bowtie or loop feeding everything.
And is the cable channel 59 a ham frequency with black helicopters circling above me looking for my pirate station?
Dave A
Old 06-30-2008, 08:30 PM
WISCOJIM WISCOJIM is offline
No audio. "Perfect video only transmission..."
Old 06-30-2008, 08:40 PM
MRX37 MRX37 is offline
Cheers,
I built one... Piece of s**t...
Oh it worked... for all of 7 feet... Could only get a clear picture by setting it right next to the antenna, and it didn't go to Channel 6, or even Channel 5...
Old 06-30-2008, 09:08 PM
Ramsey is not known for quality kits...
Old 06-30-2008, 10:48 PM
You got that right. I built their "better" AM transmitter so I could broadcast to my tube radios. Hum in audio, poor fidelity, poor range. Just not a good experience. I thought I'd done something wrong; but, my research shows that it was them and not me.
Old 06-30-2008, 10:54 PM
What would be a simple way to amplify the RF output of a VCR? Could I build or buy something cheap to do that?
Old 06-30-2008, 11:15 PM
electroking's Avatar
a- v- karma member
You do need a linear amplifier, so one thing that will usually not work
is an amplifier designed as a booster for FM 2-way radios. I don't believe
that such a product is commercially available, in view of the facts that
it could officially be used only by a TV broadcaster.
The need for linearity arises from the AM nature of the video signal
(actually VSB, but still needing amplitude linearity).
P. S.:
A cable TV booster could be the thing, but I don't know the power output
level of such a beast. Other ideas?
Old 07-01-2008, 12:13 AM
dtuomi's Avatar
Does the Nippon America UHF transmitter work, or is another one of those, put it beside the set and it migjht receive something?
David
Old 07-01-2008, 02:55 AM
Carmine-
There is a kit company that already sells exactly what you have described, in the right half of your "converter" block:
http://www.northcountryradio.com/Kitpages/vmstr.htm
I have built one or two of their amateur-TV kits, and had no trouble making it work properly as described.
