Old 06-05-2008, 12:04 PM
OK,
I went ahead and powered up the box last night to see what was going on. Now it works. What I am going to do is keep it on for the maximum allowable time of 4 hours and see if it shuts down. I opened it up anyway to see what it is all about. I am quite surprized how many radial electrolytics are in these things. There are just a few SMD caps. There are well over 20 radials, even on the RF board. The power supply is a separate panel with a SIP connector to the RF board. Acutally, easily repairable from a mechanical point of view. I am going to wait for it to fail and then immediately check the caps in the PS for leakage.
Old 06-05-2008, 02:21 PM
Git-er-done!
Old 06-05-2008, 02:57 PM
000
Old 06-05-2008, 06:33 PM
Its got a selectable shut off mode, either 1, 2, 3, or 4 hours. Im pretty sure you cannot leave in on indefinitly which is kind of strange. The unit was on for about 2 hours or so and then it just went into this intermittent blue horizontal bar display for a few seconds and simply shut off. There is a LED that glows blue when the unit is on, and red when off (standby). The led went completely out and the unit would not power up in any attempt. I did try powering it up about 30 minutes after it failed and it turned on and then shut off about 5 seconds later and again, no responce when attempted again. Im going to assume there is a marginal leaky cap somewhere in this unit. Im going to pin it down though, assuming it fails. Who knows, perhaps I have a poor solder joint and its affected by expansion of the pc board. These units do get quite warm.
Old 06-05-2008, 07:06 PM
fsjonsey's Avatar
fsjonsey fsjonsey is offline
Living The Draper Ethos
You could try picking up and dropping the unit a short distance, say six inches, to temporarily reseat any loose chips. Back in high school, that was the cure for any apple III that happened to be malfunctioning.
This device isn't a spaceship, it's a time machine. It goes backwards, and forwards... it takes us to a place where we ache to go again.
Old 06-05-2008, 08:37 PM
tcdriver's Avatar
tcdriver tcdriver is offline
AK Member
Its got a selectable shut off mode, either 1, 2, 3, or 4 hours. Im pretty sure you cannot leave in on indefinitely which is kind of strange.
The Zenith DTT900 can be set so that the “Auto Off” feature is disabled in the Setup menu. See page 9 of the manual.
Round and Round it goes
Old 06-05-2008, 09:29 PM
You could also try some freeze spray to locate thermal defects.
Old 06-07-2008, 08:00 AM
roundscreen roundscreen is offline
Well,
I'm the first to have the first DTV converter box failure, or atleast the first to report a failure on AK. I have the zenith converter box which is sold at circuit city, which is the same as the insignia box sold at best buy. While watching TV this evening with the box, the screen all of a sudden went into intermittent blue horizontal bars and then the unit shut off. I attempted to turn it back on and nothing. The red LED which is on when the unit is switched off even went out so its dead as a door nail now. No reset button on the unit. Wont respond to anything, remote or at the unit. Perhaps something in the power supply failed. Ive yet to investigate. Too late to get into that now. All I can say is that this is pretty poor. Ive only had the box about 1.5 months and it broke already. Im curious if more will fail as time passes in the near future.
This digital transition is a joke. More BS to deal with. Cheap crap converter box is an insult to the Zenith name. I think the quality fell out before the name went on with this thing. Whats next.
I have the insignia ns-dxa1 box and so far so good. Took a look in the manual and it has a 90 day warranty so you may want to check that out.
Fun wow, Now we are going to have to fix the new junk to keep our old junk running.
Ed
Old 06-07-2008, 12:09 PM
jhal's Avatar
jhal jhal is offline
Titanium bliss
I bought four of the Insignia'a yesterday, 2 for me, and two to setup for my grandmother. I haven't messed with them yet, though I did take one out to look at it. It only requires 7 watts, so it could be run off of an inverter and jumper pack along with my battery TV that has composite inputs. Should be good for a couple of hours at least since I have a rather large jumper pack.
Still, that's quite a mess of wires and setup time just to watch the weather during a bad storm. I do have a 20kw genny, so it would only be needed if it failed or ran out of diesel.
JBL XPL-200A's biamped on Yam. PC2602M & M-2 amps with
Ashly XR1001 xover, Yam. CX-830 preamp,
ADC Sound Shaper 2 EQ, Yam. Q-2031 EQ
Yam. DX-350 tuner, Tech. SL-1400 turntable,
Yam. CDX-900U cd, Pan. DVD-RP56 dvd,
Den. DRR-780 tape, Sony SLV-575UC vcr
Old 06-07-2008, 09:43 PM
kbmuri's Avatar
kbmuri kbmuri is offline
I received my Winegard RC-DT09 from SolidSignal (a month late, but finally). I have to say I like it maybe best of all. And also, the power supply is outboard already! Just a small 9VDC wall transformer with a typical power-supply jack on the back of the converter box. Real easy to make a 9V NiMH cell pack or maybe just stack a few 9V duracells in parallel for that emergency tornado-warning use. No mods to the box or P/S whatsoever, just buy a new jack from Rat Shack and go.
User menus are comparable to the Insignias or Magnavoxes, reception sensitivity looks the same too. Plastic case is a little cheap, but like a lot of the others in that respect. Physically smallest in size (width anyway). Tiny remote, but gets the job done.
I like it.
Do not attempt to adjust your set.
Old 06-07-2008, 11:03 PM
I like it.
That's very good to know. Here in East Central MS, hurricanes Ivan and Katrina taught us to be prepared for any emergency! We were without power for 12 days following Katrina and we had a 13" color TV plugged into an inverter connected to the cigarette lighter in the car. This Winegard converter should make it easier to use my Panasonic B&W portable.
Old 06-08-2008, 12:53 PM
zenith2134's Avatar
Haha, that pic looks like my room., speaker cones and heatsinks all around...
Cool Sony monitors.
Radiotvnut, that's rough.... Reasons like this are why analog tv should be kept around in some form in an emergency.
Old 06-08-2008, 06:42 PM
kbmuri's Avatar
I wondered if anyone would catch the heat sink. It's a FK660 from here: http://www.futurekit.com/products.ph...3&category=FK6
Sad to say the local distributor for them in Fort Wayne went out of business some time ago (nobody builds stuff anymore). Driving a 15-inch woofer it'll rattle the walls, and I think it was maybe 15 bucks at the time. The Sony monitors are part of a shop project still in the works. They're video only, so I had to patch the DTV-box's audio into a pair of FK660s and some speakers. Just rough-hacked on the floor for testing, a cabinet is planned (woodshop project too) sometime, when time permits.
Old 06-09-2008, 07:03 AM
Asteroid's Avatar
Asteroid Asteroid is offline
AK Member
Quite interesting reading here from an outsider's perspective. Here in Aus we've had digital terrestrial broadcasting since Jan 01. In the early days we went through much the same crap with set top boxes too, all of them suffered various incompatibilities and often would lock up requiring a hard reset. Quality tended to be very poor, with many boxes being complete dogs. The technology is pretty stable now, however the current boxes are built extremely cheap. My Teac box has died after only a few years (although my very early Teac box still works fine). It's disappointing but they're well below $50 now.
Anyway digital broadcasting is really a very good thing. Many people who only had a poor analogue reception here get good digital reception off their same antenna. So instead of snowy ghoasting junk there's perfect picture. Widescreen too. We also get HD broadcast over terrestrial digital.
Sansui AU217, TU317
Marantz LS303 floorstanders
American Audio HTD4.5, Ortofon Super OM10
Old 06-09-2008, 10:43 AM
000
