Old 05-08-2008, 02:44 AM
YamahaFreak's Avatar
YamahaFreak YamahaFreak is offline
<-- CSXT 6038, EMD GP40-2
Does this look odd?
Am I the only one that thinks this is the wrong size CRT for this Motorola? At first I thought it had just slipped down a bit, but closer inspection reveals that the OD of the picture tube is smaller than that of the frame glass. My reasoning is that the original owner could not find the replacement tube in the correct size and improvised.
Sony Trinitron Fan
Old 05-08-2008, 03:27 AM
Yes, that is an 8" set but that tube looks like a 7" 7JP4.
The 8" tube is much harder to find.
Is it yours?
Old 05-08-2008, 03:31 AM
BajaGringo's Avatar
BajaGringo BajaGringo is offline
Beach Bum
I would never be confused with any kind of authority on the subject but simple visual inspection tells me only one of two possible options:
1. The tube is missing some kind of ring that goes around it to make it fit properly, or...
2. Somebody stuck one in that looked close in size in the box...
The New BajaGringo Beach Pad is Underway...
Take Risks - Explore, Dream & Discover...
Old 05-08-2008, 04:45 AM
No, the set is not mine, but on eBay, rather.
http://cgi.ebay.com/VINTAGE-7-MOTORO...QQcmdZViewItem
Here's a similar set with a correctly-mounted tube.
http://cgi.ebay.com/NEAR-MINT-MOTORO...QQcmdZViewItem
Sony Trinitron Fan
Old 05-08-2008, 08:30 AM
Old1625's Avatar
Old1625 Old1625 is offline
The kinescope renewal as it appears in the first-shown set doesn't encourage me as to how the set will survive shipping. The seller needs first to get the back off and assure that the CRT is well anchored before packing it up as described. My money is not on the prospect of this; it looks like a pure hack-job.
Old 05-08-2008, 10:10 AM
mkoser's Avatar
mkoser mkoser is offline
Scary! Looks like something I would have done.....
I wonder what "broke" in order for the tube to fall down like it did... I assume that whom ever stuffed it in there, probably had it centered at one time... otherwise watching movies with subtitles would be a pure pain!
Thanks,
MK
Old 05-08-2008, 11:33 AM
It should look like this.
Old 05-08-2008, 12:41 PM
kx250rider's Avatar
REAL TVs have TUBES!
That's a fairly common thing to see. Probably the 8BP4 went bad when the set was 10 years old & worthless, so they stuck a 7JP4 in it to use in a back room, or something. I've probably seen ten 8" Motorolas with a 7JP4 in them.
Charles
Old 05-08-2008, 10:15 PM
Charles
That's interesting So the tube pinout was the same on both sizes, I assume.
Sony Trinitron Fan
Old 05-09-2008, 12:06 PM
Bill Cahill's Avatar
Super Moderator
Tube pin out is exactly the same on both tubes. I have that model in ratty shape, with a good 8" tube. I wrote the owner about the set. I may bid on it, and, switch my good parts to it, and, re build it.
Mine is in pretty bad shape.
Bill Cahill
Please join my forum.
Old 05-09-2008, 05:48 PM
Bill Cahill
Sounds like a plan to me, and it gets a good home, too
Sony Trinitron Fan
