Old 05-07-2008, 08:02 PM
Tugboat Tugboat is offline
Banned
Earlier I was doing just that, but in the end wound up with the G2 set to a dim raster and the colors at minimum. I was getting a dim grey raster and when I connected a video source, whites were very white and other colors looked correct. So at minimum setting they stay. I do need to readjust the G2 to an even dimmer raster as light raster lines can be seen watching dark areas of an image on the screen. Other than that, I think she's done.
I thank everyone here for their time and assistance. I doubt I'd have ever attempted fixing it without your help!
Old 05-07-2008, 08:36 PM
Banned
I do have one other question. When doing the CRT testing, the B&K instructions for testing CUTOFF was a bit confusing. The instructions say to "adjust each G2 control until meter rises ONE DIVISION. Use GUN SELECTOR switch and corresponding G2 control with color tubes." Now I figured out that I need to change guns and adjust the G2 control for each gun, but for the life of me I couldn't figure out what they mean by, "ONE DIVISION." I looked at the meter face and couldn't figure out what would consitute "ONE DIVISION." I just turned each G2 up until the needle moved from 0 to the next marking on the face. That seemed okay as the following tests for cutoff showed good for each gun.
Hmmmm.......
Old 05-07-2008, 09:00 PM
That first marking is the correct position for the cutoff settings.
Old 05-08-2008, 12:02 AM
Old 05-08-2008, 11:09 AM
Banned
I usually do a final check using the letter box bars on a wide screen TV show as a black level reference. Adjust the G2 so that they are just black when the brightness/black level control is centered and the contrast/picture is at a normal level.
Sounds like a plan. I can use Video Essentials DVD to put up the test for black level and adjust the G2. When that's done, I can use the other tests and calibrate color and tint as well.
Thanks!
Old 05-13-2008, 01:01 PM
Banned
Well, thanks to everyone here, she's up and running again! With the help of my brother and a mirror, all adjustements to brightness level, G2 level and color have been done. A quick run of video essentials and all fine tuning was also done.
So in the end, I spent about $60 to get it running again. The only thing I didn't tackle was convergence. I knew if I tried, it would end up worse. It's not really that off and I have to remember that it will never be perfect. The center is converged and so is most of the screen. Just a couple areas are off and I think that trying to fix one area will throw off another. That and once I start watching something, I forget about the areas that are off.
Thanks again to everyone here! I'm still looking for a nice Zenith console, so I'll let you know if / when I find one.
Old 05-13-2008, 08:33 PM
MRX37 MRX37 is offline
Yeah, unless you know what you're doing, trying to get perfect convergence will drive you insane.
Old 05-23-2008, 06:08 PM
Somewhere I have a big box full of NOS (new old stock) triplers both ECG and Zenith. Does anyone need any? Julian
julian
Old 06-14-2008, 12:20 AM
wb2mep's Avatar
wb2mep wb2mep is offline
Julian,
I could use a tripler for a 25GC45 set, the Sams lists a 212-141-02 (ECG 526A) and a 212-145 (ECG 528). It looks like a 212-141-05 I pulled from a 23FC45 a couple years ago. I don't know if they're interchangeable.
If you have any Zenith focus dividers, I could use a spare 63-8970 (ECG HiDiv-4) for my 25CC50. I've replaced it twice before, so they do fail.
I just put a new rebuilt CRT in it last year, and want to keep the set running - it's my living room daily watcher.
PM me if you have either of those. Thanks.
Mike
