Ham radio operators will still be able to transmit NTSC after Feb 2009. Most hams who do this mode use frequencies in the 440MHz ham band, which can be received on a TV using CATV channels 57 thru 60 with the TV set connected to an antenna. The above channels are the outputs of ham TV repeaters (similar to "translators" in the TV broadcast bands), and hams uplink NTSC signals to the repeaters. No, ham radio operators will not be doing "broadcast" style TV shows. One ham will send a signal for a while, then stop, and another ham will "talk" to the first ham via TV signals on the same repeater for a while. This could be deathly boring after a while
, but it will give your analog CATV equipped TV set something to watch...
Highest ham band for analog TV?
Hi,
Regarding this topic, can you tell me what is the highest frequency at which hams have succesfully transmitted NTSC TV signals. 73 and thanks in advance. |
AFAIK LPTV and Canadian TV will still be broadcasting in NTSC after Feb 2009. Combining that with my TV card which gets both Digital and Analog, and I'm all set.
analog(ue) tv cutoff in Canada
stations in some remote areas (not clearly defined as far as I know) to keep on broadcasting the old fashioned signals after that date. Some DX opportunities for those that are interested! |
I know it has been done at 10.5 GHz. The highest frequencies I have used personally are in the 2400 MHz (13cm) band, though. 73
Boston area ATV...
Does anyone know of any Hams in the Boston or Providence area that are doing this?
I'd love to tune in and watch this... |
Is Pittsburgh close enough?
I guess Pittsburgh, PA is too far from you, but I found this link:
http://home.tampabay.rr.com/k4lk/atv/atvgrps.htm Just type "amateur radio" "ntsc television" in google and find a few hundred links. Good luck! addendum: I just found the Pittsburgh link in the above page is not working, but some others are. Sorry. Last edited by electroking; 04-05-2008 at 09:23 PM. Reason: added info |
Not to take a dump in the punch bowl, but does anyone expect the whole changeove thing to actually happen? I know I don't. Digital TV is something I will never put a single dollar into, just like Blue-Ray disc.
For people in remote areas Feb 2009 will be the end of TV as digital signals do not have the same range as analog. This is simply because you don't get a snowy signal with digital, in effect you get no signal. Then it will hit the fan and the government may be forced to install repeaters.
![]() Some people are like Slinkies, not really good for anything. They do bring a smile to your face when you push them down the stairs. |
Yes, I do. But, OTOH, I'm on cable. ![]() Applied for a digital converter coupon anyway though.
push back against dubious claims that defy logic; be on the lookout for misrepresentations; question the lack of science when belief is the substitution; be very skeptical when the denial of the laws of physics comes into play. --jpaik |
Well, it's almost a moot point for me. I haven't watched any analog TV in probably 7 years, since soon after I got my first digital tuner.
I'm cable too; haven't really known airwave TV in my life except the odd rented house on vacation and ages and ages ago in my mother's parents' house on a very old set the make of which I forget, but it was a console without click-stop UHF and it had an orange tuner display. This was later hooked up to cable. My parents had cable since I was a kid; the remote was a big corded affair with a slider that could be set on the floor and operated with the feet -talk about luxury! I still, naturally, have cable.
My converter coupon/credit card arrived today.
FWIW, expiration date on it 6/25/2008.
