Old 01-31-2008, 10:49 PM
John Marinello's Avatar
<-- "Byron"
Beltron question...
What's the difference between the 8080-A, and the 2972-E?
They look very similar:
http://cgi.ebay.com/ws/eBayISAPI.dll....cWAT.m240.lVI
Old 03-21-2008, 01:00 PM
bbonds73
Guest
Posts: n/a
8080
We have the 8080 and and we don't know the wiring for the universal adapter. We also don't know how to post a new thread on this. Perhaps we can help each other?
Thanks!
Old 03-21-2008, 10:25 PM
kbmuri's Avatar
kbmuri kbmuri is offline
Mine is the 2972-E. It works magnificently. Let me know if I can help with any details.
Old 03-22-2008, 01:06 PM
bbonds73
Guest
Posts: n/a
I have the model 8080a and the universal adpt leads just have the clips on the ends but they are not marked which is heater,K etc do you know the pin out of the universal adpt??
Old 03-22-2008, 07:59 PM
Big Dave's Avatar
Big Dave Big Dave is offline
Dead from the neck up
The Beltron pinout:
Pin 1.: No connection
Pin 2.: Heater
Pin 3.:G1 Blue
Pin 4.: G1 Green (black and white)
Pin 5.: G1 Red
Pin 6.: No connection
Pin 7.: Heater
Pin 8.: Cathode
The world's worst TV restoration site on the entire intranoot and damn proud of it.
http://evilfurnaceman.tripod.com/tvsite
Old 03-23-2008, 12:57 PM
Old 03-23-2008, 01:26 PM
Big Dave's Avatar
The Pinout I Listed Is What Was Shown In My Instruction Book!!!
Old 03-23-2008, 01:56 PM
Old 03-23-2008, 10:59 PM
<-- "Byron"
Maybe it's a typo. I can't imagine that it would work with the cathode and G1 pins swapped. Can anyone verify the pinout by looking at an actual adapter socket (using the CRT's pinout as a reference)?
Big Dave and Andy are both right! Some testers made the grids common, but Beltron chose to make the cathodes common, and they all connect to pin 8. The CRTs with a single G1 pin use a different adapter.
Old 03-24-2008, 01:29 AM
Old 12-04-2008, 10:24 AM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
Are you sure about that? I think you have the cathode and G1 pins swapped (pin 8 is the common G1, and pins 3,4,and 5 are the cathodes). This is how my home made adapter is wired and it works. Your pinout would make it impossible to use with modern CRTs that have a single G1 pin.
My Beltron has an octal to a 9 pin adapter cable (labeled adapter A). The 9 pin connector is made by AMP. Does anyone know the exact model of connector that will fit it? I want to make my own adapter sockets.
I believe it's AMP (Tyco) 1-640511-0 using pins 640545-1.
John Y.
Old 12-04-2008, 10:19 PM
