Old 02-04-2008, 07:10 PM
truetone36's Avatar
electronics packrat
Sony KV-27510 Won't Power Up
I just got this set today.A Sony KV-27510 made in March 1994. it had been stored in a garage for over a year. It
worked fine when it was stored, but upon bringing it home I can't get it to come on. Any suggestions on where to start? I'm mainly a tube t.v. guy
with very little experience with solid state sets, but this is too nice a set to just toss, so I want to give repairing it a try.
Old 02-04-2008, 07:18 PM
Check for a shorted horizontal output transistor. Also check the two transistors mounted on heat sinks in the power supply for shorts. If they are shorted, there will be a small round white resistor less than 1 ohm that will be open. Also, resolder the connections on the horizontal drive transformer. The loose connections are what takes out the HOT and in turn blows up the power supply transistors.
Old 02-05-2008, 11:06 AM
kx250rider's Avatar
REAL TVs have TUBES!
My suggestion exactly. A note on the resistor: It IS THE B+ FUSE. You must replace it with an exact equivalent, or the set will blow to oblivion if the short that caused it isn't fixed. That resistor is R607, near the edge of the board where the 2 heatsink-mounted regulators transistors are (2SC4834MN). Technically, you should replace the thermistors too; VDR601,602, & 603. However, many people don't.
Charles
Old 02-05-2008, 12:43 PM
Also, the correct model number is KV-27S10.
