Old 01-26-2008, 08:33 PM
MRX37 MRX37 is offline
How to operate an HDTV
This is similar to my post on How to operate a tube TV This is meant to be a parody. Real HDTV's (hopefully) don't work like this.
With the advent of digital TV and the realization that digital video can be compressed to save on space in the frequency spectrum, the FCC has mandated that all analog television cease to broadcast on 2/17/09, so that they may make a shitload of money selling off the unused TV spectrum.
While digital TV is an overall improvement over the traditional low resolution NTSC standard, there are a few issues that may crop up:
COMMON ISSUES:
PROBLEM: The picture on my screen has all these artifacts and the sound is all muddled!
SOLUTION: Broadcaster is using way too much compression. Complain like crazy or pay money for better signal quality.
PROBLEM: The damn picture keeps freezing and pixelating!
SOLUTION: Buy a better antenna. Digital signals are either there or not there. If the signal strength drops below a certain threshhold, the TV will stop showing a picture. These issues tend to crop up when your TV is more then 30 feet away from the TV station's transmitter. After the 2009 switchover is complete, coverage will be extended to more then 60 feet away from the transmitter.
PROBLEM: On my analog programs, the people now look all squashed and fatter then normal.
SOLUTION: This is due to the differences between 4.3 and 16.9 aspect ratios. Most HDTV's have a feature to automaticlly adjust the aspect ratio. You need to go into the menu, figure out how to navigate it, reset to factory defaults after you screw up one of the 3500 settings, find the feature that allows analog broadcasts to be displayed properly, and turn it on. Make sure you have the proper permissions to adjust the settings on your TV. If you don't, please contact your system administrator.
PROBLEM: How the f*** do I change the channel?!
SOLUTION: There are two ways to do this: There's the remote control, which has many tiny, hard to see buttons, and there are buttons on the TV which are also tiny and hard to see. Generally, the buttons with arrows will either change the channel or the volume level. Try experimenting. You can always reset to factory defaults after you screw something up. After you lose the remote or break it out of frustration, you'll have to order a replacement.
PROBLEM: I'm getting pop up ads while I'm watching my shows!!
SOLUTION: Your TV may be infected with spyware. Go into the menu and run the diagnostic software. Be sure to update your TV's BIOS regularly.
OTHER TIPS:
Do not break the original remote no matter how tempting it might be. The original remote is the only device that can access the TV's menu, control the TV's web browser, close pop up ads, delete messages, record videos, and format the TV's hard drive. Universal remotes will not give you access to all these features no matter how many different ones you buy. Oh you'll get close after buying about 10 or 15 different universal remotes... but you'll never find one that can do everything the original can.
If you do lose or break the remote, replacements can be ordered from the company for about $10.00 each. If the model has been discontinued, which happens every 6 weeks, then it will cost around $1400,00 for a replacement.
Get the extended warrenty when you buy an HDTV. HDTV's are designed to fail one or two days after the warrenty expires. An extended warrenty will ensure your TV lasts longer. After it fails, it's unrepairable. Seriously... Don't try to repair it... PUT THAT SOLDERING IRON AWAY! BUY A NEW TV INSTEAD! WE NEED THE MONEY DAMNIT!!
Do not expose your new HDTV to small children, cats, dogs, or reality programming. Doing so can danage your TV and void the warrenty.
By following this information, you can get several years of enjoyment out of your new HDTV. After it breaks and you buy a new one, you can enjoy that one for several more years.
Old 01-26-2008, 08:45 PM
That's tongue-in-cheek, but its also pretty much the truth...
Old 01-26-2008, 08:57 PM
Adam's Avatar
Adam Adam is offline
Never tried one of those HDTVs, but it drives me nuts how I can't operate my dvd player from the unit itself and always need the remote.
Old 01-27-2008, 12:19 PM
NowhereMan 1966's Avatar
NowhereMan 1966 NowhereMan 1966 is offline
Slave to 1 Cat
I love it, got a good laugh but sometimes I think you are very close to the truth.
Mom (1938 - 2013) - RIP, I miss you
Spunky, (1999 - 2016) - RIP, pretty girl!
Rascal, (2007 - 2021) RIP, miss you very much
Old 01-27-2008, 12:44 PM
jpdylon's Avatar
jpdylon jpdylon is offline
<-- sucker for old sets.
I have up on HD the first time I tried to pull in a signal. Cable with HD service is not worth the money here, and I was tired of the damn thing freezing up every time the signal got crappy.
Since then, the HDTV has become my 30" computer monitor
Jordan
Old 01-27-2008, 02:23 PM
A great follow-up to your other post.
Old 01-27-2008, 02:49 PM
I figured that since I poked fun of the older tube TV's, it was only fair to poke fun of the newer HDTV's as well.
Old 01-30-2008, 10:02 AM
This is so close to the truth that it scares me a little. I love my old TV
Old 01-30-2008, 12:36 PM
RetroHacker RetroHacker is offline
Electronics Accumulator
You forgot to explain the instructions on changing the brightness or contrast of the picture:
First you must purchase the service manual from the manufacturer, making up a fake company name because they will only sell this maual to a repair shop. After spending $48.99 on the manual, read through the 12 pages of tiny text and menu options. Enter the 67 digit code into the remote while holding "Channel Up" on the television and tapping "mode" on the remote. Once you're into the settings screen, you can use the navigation buttons to change the menu - NO! Not the DVD navigation buttons! The other ones! Now you've changed the menu language to Japanese, and the only way to reset the thing to factory defauts is to enter another 67 digit code while pressing "Volume Down" on the television. But this code is different now, since you've just changed the set to the Japanese version of the firmware - you must order the Japanese manual from the distributor in Japan.
-Ian
