Old 09-13-2006, 02:12 PM
One more quick question,
The big resistor in the power supply, it was 2.7 @ 15w in this set, I could only
get 2.7 @ 25w or 2 5.6ohm @ 10w and parallel them, I did the latter.
Is the extra wattage a problem, I don't want to create a fire hazard.
Old 09-13-2006, 05:12 PM
TedJ TedJ is offline
AK Member
Wattage on a resistor tells you how much power the resistor can dissapate. So using a resistor with the same resistance (ohms) but a higher watage will be fine. As a general rule as long as the value is the same and the wattage is the same or higher its fine. A resistor rated for less wattage would possibly be a fire hazard. If anything the higher wattage resistor will heat up less and last longer since it's being stressed less. Only thing is that higher wattage means a physically larger part, so make sure it will fit in the space you have. -Ted
Old 09-13-2006, 11:30 PM
OK, the patient is buttoned up and ready to go home!
I replaced the 15mf cap and the power resistor and let it run for several hours with no problems. The B+ was running at 141.2 volts!
It was actually kinda fun being able to get a modern set running again.
Thanks to everyone for the help, I wouldn't have gotten past the fuse on this one without it.
