Old 10-25-2005, 10:08 PM
zenith2134's Avatar
GTE Sylvania Color Tv - Age? Junk?
I have this Sylvania , model CE3181W. Got it going after cleaning up the HV area and all controls inside and out. Tube is worn out though, (although still not finished with it). I was wondering about its age and if its a Pre-Phillips. Thanks guys
Old 10-25-2005, 10:31 PM
polaraman's Avatar
polaraman polaraman is offline
<--1956 300B
sams 1414-3 I would say about 1974 or 75?
polaraman
Old 10-25-2005, 10:54 PM
JCFitz JCFitz is offline
If It says GTE Sylvania it's definitely pre Philips.My grandmother had a 1975 GTMatic console she bought new for years.It had a diode go bad under warranty.No problems til it got hit by lightning in 84'.The lightning completely blew apart the antenna rotator and Wineguard booster power supply hanging on the back of the tv leaving a 4 inch hole in the back of the set where it once hung.The tv was repaired by the place she bought it.In the box were some rectifiers,a couple of transistors,the filter cans and the speaker with the cone completely ripped from the frame.A modern tv taking that kind of hit would be most likely beyond repair.Would have probably fried every integrated circuit on the board and lots of tiny thin traces (common on modern tvs) burnt in two.I've seen it on modern Philips junk after it got hit by lightning.The set nearly got it again a few days after they got it back lightning hit the house and magnetized the CRT.A degaussing coil fixed that.Tv played great right into the 90s.By then I had a brightener on it to help it's weak green gun and propensity for blue.The instant on feature had pretty much made it beyond rejuvenation.Still very watchable when I took it to an auction and only got $1.The auction didn't have an antenna or cable and was in a metal building.I always showed up with a VCR to make sure they could see it work.I got stuck working late and they couldn't get any reception on it.The guy that bought it told me his mother was still using it when I last saw him just before that auction went out of businness in 1999.Those sets are workhorses.I know.I played the crap out of that tv when I was a kid.Would leave it on all day long when I was at her house in the summer even when I was outside playing and just come back in and watch it later.Hopefully you will fix it up.If it has it disable the instant on.Made a lot of CRTs die prematurely.I might have kept her tv if the CRT hadn't been getting weak.She always hated the newfangled remote Zenith I replaced it with and I own now after she past.She would get it in VCR mode with her thumb and couldn't work the tv.
Old 10-26-2005, 12:02 PM
kx250rider's Avatar
REAL TVs have TUBES!
That may have the black face tube! If so, have it rebuilt and it will give the most incredible color and contrast of any tube I've seen. I have one (25VDMP22) in my daily TV; Zenith Chromacolor I.
Charles
Old 10-26-2005, 04:17 PM
zenith2134's Avatar
hey guys thanks for the info. Yes, it does have a black face tube. The tuner knobs for VHF are broken off, and now I have to remove the tuner for cleaning, and repair of tuning shaft.
