Old 10-25-2026, 06:15 PM
TinCanAlley's Avatar
Couple of Questions on Convergence and H-Hold
I decided it is time to find out if my convergence issues are user error or not. Against my better judgement I decided to mess with it again in hopes of figuring out why my results are what they are. Of course many will know this is on a CCII 25EC58.
I'm attaching a pic of the best center viewing convergence I can get. I know the sides will never be perfect, but they must get better than this. If I move the blue on the right side up, it messes up the blue on some areas on the left side. Pretty much the same if I try to line up the green and red on the right side. I've left it pretty much like this as it is less distracting on that side of the screen. The left side is pretty close, but if I try to make it better, it messes up convergence elsewhere along the grid. I've replaced all the pots out of spec and all of the coils. I only adjust the coils with a plastic tool.
The other question I have is about interaction between convergence pots and coils. There are three for the top of the screen and three for the bottom of the screen. If I adjust the bottom controls to line things up, the top moves as well. Not to the degree of the bottom, but enough that I have to keep going back and forth trying to get them where I want them. I know there is interaction between controls, but is the top and bottom supposed to interfere with each other?
On the horizontal hold... I have the original module installed and no movement of the control will cause it to lose synch. However, the image is not centered. It is off to the right by about 3/4" If I rotate the hold control it moves even more to the right, so rotating all the way the other direction, fully, gets me to being off by 3/4". In looking over the control I notice it is a shaft that engages a coil. Since there is a stop on the control, I'm assuming you're not supposed to adjust it more in either direction. Is this correct? I'm hoping that if I can go just a bit further I could move the image to center. The newer module I had in it before it died centered the image perfectly.
So can the coil and shaft be disconnected so I can reposition the shaft rotation to give me a little extra image movement or will that just throw off the synch?
Other than these 2 minor issues, the set has been running great. I am still torn between un-plugging between uses or leaving it plugged in. Knowing that the tube is good with many hours left in it, I am worried about the heating element.
Thanks! Hope everyone is doing well.
Old 10-25-2026, 08:45 PM
Do you have the service manual for the set? The published order of convergence adjustments is usually designed to prevent ending up with an excessive error in one area of the screen. Rectangular tube horizontal dynamic waveforms usually consist of the same horizontal rate parabola and sawtooth waveforms as a round tube, plus a higher frequency adjustment that affects things halfway between cneter and edge. Your picture looks like MAYBE you have walked the adjustments into a state where the horizontal rate adjustments are not not really right but are being compensated by the higher frequency adjustments from center to halfway out, and beyond that distance the compensation is wrong. (Or something like that, anyway.)
In other words, MAYBE adjust the H parabola so the blue is less low at the edges and slightly high halfway out, then adjust the high frequency to cancel it in both places.
Sorry I don't remember what names they put on these adjustments, just what the waveforms do.
Old 10-29-2026, 03:17 PM
I went back over the convergence sticky here, but still left feeling I'm doing something wrong vs. a problem in the circuit. I do have the SM and I'm posting the convergence section. Other than it noting to do the miscellaneous first (purity, etc.). I did those years ago and a red raster shows the purity is still good. The remaining part does say whether to go in the order listed, or if those are just the control information and not that they have to be done in that order.
So what I did was center convergence and then went from top down in the adjustment section, touching up center after going through all the controls and repeating that process. I now have a better right side, but minor convergence issues on some horizontal and vertical sections that didn't exist when the right side was as shown in the previous attached pic.
While what I now have is decent for color programs, it is very distracting with B&W programs. While I know I can't get it perfect, I need to find a way to get the best convergence for B&W. If I can do that, the color programs will not be an issue.
I watched a video of a CCII with the chassis just before this one (D something) and they convergence controls seemed identical and the image from their SM look identical to mine. He got his almost perfect.
Old 10-29-2026, 05:32 PM
mrjukebox160 mrjukebox160 is offline
IIRC, you should do it in the order shone. Keep in mind not all CRT's get perfect, even more so if the CRT has been replaced.
Old 11-01-2026, 06:55 PM
Original CRT, but with the set being 53 years old, maybe there's a slight issue with the yoke or other sections of the convergence circuits. I was going to use a scope and compare to service manual, but I'm assuming that since I get it as it is now, the waveforms would probably match up.
I think I'm going to kill the blue gun and try just to align the red and green. If I can do that, then I'll bring back the blue and align it best I can to the others.
Old 11-01-2026, 08:59 PM
I think you should check all the components on the convergence board first, be sure
all the caps & Resistors are in spec. Then set all the controls to mid point since
you have such a far out of wack blue.... Then follow the procedures you
posted above, the order is correct and should work out fine It's just
the way I use to do it.... And just for observation comment,
overall it looks good, very good except for the blue.
Don't rule out loosening the 3 magnets and turning
them a little if you can't get it. Remember it
looked almost prefect from the factory, no
reason you can't get it there again.
Old 11-06-2026, 10:08 AM
What 3 magnets are you referring to? I know only of the static convergence magnets.
