Old 06-19-2026, 09:38 AM
Eico 369 project started!
Due to the fact that I have so many sets with the older style front end, that are working, but can do with an alignment for optimization, I went out and got a used parts/repair Eico 369 gambling on that the seller really did not know anything about it, and it was a good candidate for restoration, ( it is! ), and also knowing that an extensive multi part video was posted about one a few years back. ( bandersen).
Now I have not started any work on it yet, other than confirming it does power up w/o any problems and seems to be doing something!
I have the rebuild kit which has all needed parts, ( quality caps, cheaper that getting them from Mouser), this kit includes a silicone diode to replace the selenium diode CR1 in the sweep width circuit, as it was mentioned in the said video, this circuit can be problematic, needing tweaking of the resistors to get correct width, so before I even start this project, the question is, CR1, leave it selenium or change it to a new diode?
Won't a new diode change the characteristics of the circuit? Then again, the selenium diode is most likely old and starting to degrade. :O
Old 06-21-2026, 12:22 PM
kf4rca kf4rca is offline
Will that one do sets with the 21MHz. IF amplifier frequencies?
Old 06-22-2026, 08:17 AM
Yes, it will. That's why I got it.
If you look up bandersen's videos on it, he uses one to align a Admiral 17T1.
Old 06-25-2026, 04:29 PM
Keep us posted with your progress. As I recall, a silicon diode will give a higher B+ voltage thruout. You might have to add a dropping resistor to keep your voltages correct with the schematic.
I've got a Sweep Systems International model 450 sweep generator that I can't find anything about. It doesn't do markers. Its from the Seventies I believe as it has a BNC connector on it. I heard that SSI is the fore-runner of Wavetek.
Old 07-16-2026, 10:31 AM
dtvmcdonald's Avatar
I have an Eico 368 with the same sweep system. It was very easy to restore with no problems. However I was never able to get the sweep dial to match the actual frequency. I could get the markers fairly close. One big problem is that I was never able to get radiation from the line cord really low.
Old 10-20-2026, 01:48 PM
Kentos Kentos is offline
Испытайте азарт и выиграйте реальные деньги на http://jpc-spb.ru/! Огромный выбор слотов, настольных игр и бонусов ждут вас. Доверьтесь удаче с быстрым заработком в онлайн казино!
Old 10-21-2026, 04:25 PM
[QUOTE=DELETED[/QUOTE]
It's for crap like this that I wish some of us regular users had moderator access, because if I had the power, this idiot would be banned so fast he would not know what hit him...
Old 10-26-2026, 11:08 AM
English please!
Slava Ukraine.
