Old 08-20-2024, 10:08 PM
jhalphen's Avatar
jhalphen jhalphen is offline
Hi to all,
Hi Zsuttle,
SAMS 20 page manual here, 2.9Mb pdf :
https://www.earlytelevision.org/pdf/...ams-0736-4.pdf
The CTC-16X is also available.
The ETF Museum database is the "go-to" place for vintage B&W & color TV data.
Color TVs by Brand :
https://www.earlytelevision.org/tv_s...ams_color.html
Hope this helps,
Best Regards
jhalphen
Paris/France
Old 08-26-2024, 02:40 PM
Zsuttle's Avatar
Zsuttle Zsuttle is offline
Originally Posted by jhalphen View Post
Hi to all,
Hi Zsuttle,
Hope this helps,
Best Regards
jhalphen
Paris/France
Thanks for the info, but I've been using this SAMS from their site, I was looking for the RCA service manual. The RCA manual has a little bit more information about adjusting the set, I was able to buy one online.
Onto purity and convergence. Does anyone reccomend a good lubricant for the convergence pots? I've got a couple that are stiff, and was able to get a few moving with some contact cleaner, but they're still harder to turn than some of the other pots on the board. I was thinking dielectric grease, or I've seen F5 fader lube/cleaner reccomended for other applications.
"If it isn't broke, you aren't trying hard enough"
Old 08-26-2024, 06:18 PM
This is par for the course with the pots on the convergence PCB,they always tend to be hard to turn no matter what, as they are 2W wire type pots, and I have never seen one that was not stiff, and It's good that they are, cause you dont want them to move once set.
I would leave them as is.
Old 08-27-2024, 09:48 AM
If convergence are ok, and not have bad contacts, is possible to leave as-is.
But once I had bad contact issues with the a convergence board that makes the vertical jumps or jitter. Cleaning the pots solved the problem.
Old 08-29-2024, 03:30 PM
cj_reha's Avatar
cj_reha cj_reha is offline
I don't have much to add other than I'm glad to see someone saved this set. I was tempted, but I just don't have the room. Best of luck dialing it in
When you lower your standards, you set a new standard!
ISO: Mitsubishi 6CT-338, Sony Chromatron 19C70/100, Yaou "Colornetron" GTC-9, etc...
