Old 03-23-2023, 11:15 PM
That keystoning makes me wonder if the yoke failed, a cap in the yoke shorted, or the vertical is leaking into the horizontal circuit elsewhere.
Old 03-24-2023, 10:41 AM
Originally Posted by mr_rye89 View Post
Well we have a sudden shrink of picture for some reason. Horizontal lock is shaky. I checked for HV arcing, none of that. Changes the 1 Meg resistor on the hv anode, swapped in some other horizontal oscillator and sync separator tubes in for good measure. This guy is getting ready to get mothballed again
It looks like the yoke failed when you were working on it! Not totally unheard of, when waking up a set that wasn't used for at least 60 years.
A 52 degree yoke. I have one from a scrap Admiral that should work!
Old 03-24-2023, 10:25 PM
mr_rye89's Avatar
mr_rye89 mr_rye89 is offline
Thanks guys for the guidance (and possible replacement yoke)
I looked at the yoke, checked the resistors on the vertical windings, high but not crazy, and the capacitor I replaced on the horizontal windings was a 47pf and I read it wrong and replaced it with a 470pf. D’oh! Put a crusty 47pf ceramic disc on and now have normal-ish deflection. That stupid drive line is still there but not as bad and the width is still uncontrollable but we’re doing a lot better!
Excuse the blanking in the photo and crooked yoke
File Type: jpg 12308738-47B0-4DA9-8376-01E9CE053A79.jpg (69.5 KB, 64 views)
Old 07-01-2023, 03:56 PM
mr_rye89's Avatar
Back to beating this dead horse. I got the sound back after messing with the 4.5mc coils. The horizontal circuit still isn't completely happy, kinda stretched on the left side and the width control still doesn't work. The horizontal drive line can be mostly adjusted out. The yoke may still be suspect, but there's two 24pf 3kv capacitors in series (makes them 12pf at 6kv?) that couple the oscillator to the yoke/damper that I haven't changed yet due to finding suitable replacements. So close.........
Old 08-25-2023, 04:00 PM
mr_rye89's Avatar
I found a thread about horizontal drive lines and Barkhausen interference. I may play with this set over the weekend.....
http://www.videokarma.org/archive/in.../t-266745.html
Old 08-28-2023, 08:31 PM
mr_rye89's Avatar
Drive line has been eliminated! I took C64 out of the circuit completely (.05uf capacitor between the cathode and one of the grids of the horizontal output tube)
The horizontal width (L10) and Horizontal linearity (L9) coils still don't do anything when adjusted. I know the slug in the linearity coil moves with the adjuster screw, and I think it does with the width
I have a good solid bright contrast-y picture otherwise, focus is kinda poor at the sides. I have played with the position of the focus coil/electromagnet to get things centered I guess.
Old 09-03-2023, 08:04 PM
mr_rye89's Avatar
I think I have this dialed in close enough. The horizontal width slug is cranked out quite a bit and I hooked the doorknob cap back up and was able to shrink the width of the raster to where its not spilling over too much. I have been playing with the focus coil (electromagnet?) position to get the best centering/sharpness, focus is cranked all the way up and we're kinda soft on the edges.
We'll call this mostly done as it is watchable and nothing seems to be smoking/burning/red plating.....
Old 09-05-2023, 08:36 AM
kvflyer kvflyer is offline
Looks good!
Old 09-10-2023, 01:11 PM
mr_rye89's Avatar
Thanks. I tweaked it a bit got a little better picture, and obviously it looks better in real life
