Old 02-02-2023, 12:20 PM
Chris K Chris K is offline
RCA KCS100D Chassis VOT Issue
Hi all. Have a cool little RCA 8" Model PT-710 with an open vertical output transformer. Tried to find the break but couldn't. There are a couple of chassis for this set and I have model KCS100D that has a VOT with a 32-1 ratio and a 22k Primary. The "B" chassis' VOT has a 35.8-1 ratio with a 27k Primary. There was a Thordarson 26S12 replacement on eBay for the B model and I thought I'd grab it and see if I could get it to work but no go. A direct replacement I believe is a Stancor VO-107. Can't find one on the bay or in the ETF parts lists. There is a Thordarson S2620 that is a 32-1 ratio but I can't find the specs on the primary resistance (can't find that one for sale anywhere either!). I guess what I'm asking for is any ideas on the full specs for the S2620 and would it work? The RCA part number for the correct VOT I need is 103266. I guess I could get a donor set because these small TVs can be shipped easily but I'm sure there are options I don't know about. Anyway, I'd love to get this cool little TV working again. Thanks for listening!!!
Old 02-02-2023, 02:00 PM
I think there were a different Vert output tube and circuit between the 2 versions of the chassis...If you are trying to use a vertical output transformer for the other version, then you need to change the tube and circuit wiring to match what the transformer was made to work with.
Old 02-02-2023, 02:11 PM
That's right Tom...my chassis uses the 6CM7 and the VOT I bought is for the 6CG7 in the B chassis. Not only is the tube pin wiring different but the vertical linearity pot is wired differently and a bunch of resistor values are changed. I guess it was foolish to use the B chassis transformer but...I'm learning! I suppose I'll have to either get a donor or wait until an appropriate replacement becomes available. Are there any considerations other ratio and primary resistance I need to be concerned with when looking for a replacement?
Old 02-02-2023, 04:22 PM
Tim's Avatar
Tim Tim is offline
The resistance will not matter, it is the turns ratio that matters. Sams lists the resistance to help in troubleshooting, not as a required spec. Stancor made a universal VO transformer supposedly good for 5:1 to 50:1 if you can find one of those VO-109. Do you mean Thordarson 26S20? You wrote S2620.
Tim
Old 02-02-2023, 05:36 PM
Yes transposition error! I believe the ETF lists a Stancor VO-109 as being in stock. I'll check.
Old 02-02-2023, 05:38 PM
Nope...it's a VO-110 and a VO-117
Old 02-03-2023, 12:09 AM
Why not use that new transformer for the other chassis version and just change the tube and resistors to match it?....I mean yeah these sets are a bit cramped to work on, but having done one myself in one day back on Thanksgiving (away from home no less), I can say that these aren't so bad to work on that I wouldn't rewire the whole vertical circuit to make the transformer work if I were in your shoes.
Old 02-03-2023, 12:36 AM
Vertical circuits, RCA 8PT70xx:
Quite a few differences. Note even the HV is different
File Type: jpg 4B316F85-6315-45A9-B916-A6A242683043.jpg (122.2 KB, 15 views)
File Type: jpg 81219B54-B55E-4C01-8331-C2C5D2332F2F.jpg (130.7 KB, 18 views)
Old 02-03-2023, 01:05 AM
TV-collector's Avatar
TV-collector TV-collector is offline
Hi Chris,
A vertical output stage is like/about an audio output stage constructed.
(higher voltage/low current at the primary, lower voltage/high current
at the secondary)
As others said, there is not a big difference among output transformers.
You have here now no additional tabs.
I should try to use a transformer from a parts set with the same angle
in the vertical deflection.
It is not so complicated like interchanging transformers in the horizontal
output.
Good luck!
TV-collector
Scotty, beam me up, there is no more 4/3 Television and AM radio in Germany!
Old 02-06-2023, 08:39 AM
Thanks all. I think I'll keep my eyes open for a donor although making sure it's a D chassis first may pose a communication challenge with the seller if they are not minimally vintage TV savvy.
