Old 05-16-2022, 07:49 PM
pac.attack76's Avatar
Stuck in the past
2019 LG 55 inch TV model 55UK6090PUA sound only. No video
Tv turns on with sound but no video. Backlight working.
Genesis does what Nintendon't
Old 05-16-2022, 08:55 PM
damen's Avatar
damen damen is offline
If there are at least 2 ribbon cables going from the T-con board to the screen, try disconnecting them one at a time and see if you then get 1/2 picture when you turn on the set.
Old 05-16-2022, 08:57 PM
Stuck in the past
I'll try it and let you know.
Old 09-04-2022, 01:17 PM
Stuck in the past
Going to open it up today and check it out. Will post what I find in a few hours.
Old 09-04-2022, 01:52 PM
Stuck in the past
2 cables run to the screen. Removed one and got this:
Old 09-05-2022, 07:07 AM
kf4rca kf4rca is offline
There was a 50+ set in the dumpster at the free public recycling bin yesterday.
(The guy who runs the place really just likes computer stuff- presumably for gold harvesting.) He throws the TV's away!
I couldn't get it out. I was thinking, where are you guys when I need you!
Ha Ha.
Old 09-06-2022, 05:41 AM
It looks like you might have a bad board or two, someone once gave me a 55" LG Plasma 3D Smart TV that would give a blank screen when powered up, and it turned out to be a bad board, I replaced it with one someone was selling on eBay that was parted out of a working set that someone broke the screen on (with a Wii controller) and its been working fine since then.
Old 09-06-2022, 10:23 AM
Stuck in the past
Soaybe the entire t con board needs to be replaced.
Old 09-06-2022, 08:18 PM
damen's Avatar
When you removed one of the cables did you have a source connected to the set ? You should get half an image, not just a light screen. Unfortunately, getting half an image during this test usually means the screen is bad.
Old 09-06-2022, 08:21 PM
Stuck in the past
I'll double check. So on one cable, or the other, I should see half? I did try the menu, buttons on remote, etc. And saw nothing.
Old 09-06-2022, 09:47 PM
On mine (granted mine was a 2012 vintage set) it only had one T-con board and that was all I had to replace in mine to get it running.
Old 11-18-2022, 05:33 PM
Stuck in the past
I cannot get a single pic, half screen or otherwise on this. No sound either. Not sure what to do at this point
Old 11-19-2022, 11:35 AM
You should have sound.
Try connecting an oscillator to the A/V inputs.
Here's a link to some helpful troubleshooting tips:
https://fliphtml5.com/osspz/lhwm/basic
That link used to be available as a downloadable pdf file but I guess it got removed.
Old 11-19-2022, 12:08 PM
Stuck in the past
I don't have an oscillator. Is it possible screen is bad or should I order the replacement board and take a chance?
Old 11-20-2022, 08:08 AM
Do you have a vcr that you could connect to the A/V inputs to get sound?
You might be stuck on A/V inputs.
There is also a part 2 to the advance troubleshooting techniques:
https://pdfcoffee.com/qdownload/lcd-...-pdf-free.html
