Old 09-19-2022, 10:10 AM
Notice pin 8 of V6 on the 6HS8, it gets power from 640v boost via R92, if the horizontal oscillator is NOT working, then this voltage is obviously not there for the plate to use, making the tube NOT happy, it will try to get power from someplace else, like the grids, this can overload and damage the tube.
From what I understand, V6 is not needed in the set for horizontal oscillation to take place, can be removed while you debug the horizontal oscillator circuit, it IS needed to sync it to incoming video however.
And as been stated many times by many here, an oscilloscope, even a crappy $35 one, would be a great aid to you at this point.
Old 09-19-2022, 10:49 AM
What if the ohms on the flyback were out to a degree would this prevent the oscillator from running. With the 6hs8 out the 190 rail is dropping bad down to 35 v. I think it’s obvious that whatever the problem was has now disabled the oscillator for good which is a good thing maybe now I can somehow track it down so now it’s a dead short probably between a resistor otherwise it would burn the fuse wire.
Old 09-19-2022, 11:11 AM
Possible short/ bad part, there are 8 connections to the 190v line, all must be checked, starting with both sides of R215, if 275V is OK, then R215 is suspect, or C2c, or anything that connects to 190v.
But, that is the reason for loss of horizontal oscillator, it needs 190v to work, find why you lost 190v, and it should work again.
Old 09-19-2022, 11:30 AM
Most likely suspects are, soldering errors, opens or shorts.
or
C61 , R215 ,C2 section c
All other links to that line are via 2k or higher resistors, and would be getting quite hot if shorted.
Old 09-19-2022, 11:53 AM
I had subbed another cap c2 c and the 15k resistor checks 18k so on to the next.
Old 09-19-2022, 12:48 PM
18k is just on the outside edge of tolerance (20%) and very out of 10%.
You may wanna change it with a new 1w 15k one.
Cap cap c2 c subbed with 10uf 350v?
Old 09-19-2022, 12:50 PM
Any chance that the 190 and 145 volt supplies are swapped on the schematic? The 15k resistor appears to be too high a value for the current that it must supply. The 190 supply as shown appears to be very weak!
Old 09-19-2022, 01:04 PM
The 190v I never had a problem with that rail until now and the 15k resistor is getting warm like there is a draw and I pulled half the tubes and the cap I subbed was not 350 10 it was bigger voltage and uf
Old 09-19-2022, 01:06 PM
And yes that would have made more sense for it to be the other way around since there is only 2 connections and 190 having 8.
Old 09-19-2022, 01:25 PM
You will have to track down what the draw is, I would still suggest replacing that 15k with a new 1w one, then follow the 190v line to every place it goes, it has to be something, if it's feeding a resistor that's shorted on the other end, then that will be getting warm. As mentioned, 18k is a tad bit high, you have nothing to lose by replacing it with a same value 15k 1w resistor, it will just be more durable.
Old 09-19-2022, 01:28 PM
I have a 15k 1 watt wire wound I could put in but I know that won’t fix it I will have to trace down all 8 locations that feed 190v.
Old 09-19-2022, 01:55 PM
Chances are the problematic end also has a resistor on it's side and is getting warm as well, an IR camera would be handy for this such thing.
Old 09-19-2022, 02:16 PM
Tom9589 Tom9589 is offline
For a number of years as a teenager, I worked on TVs without an oscilloscope. When I finally got one, I couldn't imagine working on TVs without one. Even a cheap one with low bandwidth would make it a lot easier for you to troubleshoot this set. An oscilloscope will tell you whether an oscillator is running and if the waveform is correct. You just can't do that with a DVM. You should be able to find something on eBay. I got my last one from eBay and it was a high end Tektronix for a very good price.
If my house were to catch fire, the Tektronix oscilloscope is the first piece of gear I would remove. 'Nuff said.
Old 09-19-2022, 02:34 PM
Well there are several 2 and 3 watt resistors that normally get hot and up until now I had all tubes out and still a draw and the 275v is around 250v so if one goes down all are going to be low as well. So at this point I’m still thinking it may be a ceramic cap that may have been a problem and now is possibly shorted. How to find I don’t know it means turning this chassis into spaghetti with all clipping and checking and resoldering. Omg what a headache.
Old 09-19-2022, 02:54 PM
Running raw w/o tubes is not recommended, UNLESS you limit input voltage with a variac.
Reason is, the power supply is non regulated, and dependent on load, the tubes in the set ARE that load, w/o the tubes in the set, the voltage generated can exceed the ratings of the filter electrolytic capacitors and damage them (internal shorts), when you run w/o tubes one must be very careful not to let the bias voltage spike above the rate the capacitors can tolerate, or it can be really bad.
