Old 06-14-2022, 04:41 PM
pac.attack76's Avatar
Stuck in the past
Ok, changed the 35v 220uf and now it looks like this:
Genesis does what Nintendon't
Old 06-14-2022, 05:47 PM
jbattles's Avatar
jbattles jbattles is offline
jbattles
deflection has gotten better. you said it outside for awhile, now you can sub a cap underneath. just make sure its + to + and - to - until you find the bad one. Theirs a bad cap in there close.
Old 06-14-2022, 07:57 PM
Stuck in the past
Yeah, the next cap in line is a 35v 1000uf. I have a 35v 1500uf. Ok to use?
Old 06-14-2022, 08:21 PM
jbattles's Avatar
jbattles
yes you can.
Old 06-14-2022, 08:54 PM
Stuck in the past
Cool. Tomorrow's agenda👍
Old 06-15-2022, 07:22 PM
Stuck in the past
Replaced the 35v 1000uf and here's how it looks:
Old 06-15-2022, 09:20 PM
jbattles's Avatar
jbattles
well after i looked the picture again that's not the vert section. coming from the yoke there should be 2 wires one yellow and one green. follow them down to the chassis that will be the vert section. same thing find the bad cap.
Old 06-15-2022, 09:32 PM
Stuck in the past
At the yoke, I got two sets of wires. One set says yoke H which as brown and red. The other set is yoke V and it's brown and black.the brown and black run to the caps we changed. I do have a yellow and green but they come from the board on the gun.
Old 06-16-2022, 10:01 PM
jbattles's Avatar
jbattles
https://elektrotanya.com/rca_chassis...wnload.html#dl hey i found the service info. with thosehttps://elektrotanya.com/rca_chassis_ctc203_training_manual.pdf/download.html#dl sets the tuner ground did not have goo solder from the factory. that cause the e prom go bad, but first check the voltage on the vert side only see if what the reading is. plus do a ohms check on that side. i leaning towards bad vert chip. the e prom was just for a few chassis. the bread butter of shop. give that a try.
Old 06-16-2022, 10:26 PM
Stuck in the past
Will do. I'll get back with you.
Old 06-17-2022, 07:26 PM
Stuck in the past
I'm not good this multimeters except when using for home wiring etc. I took the board to a guy and showed him what u said. He said he can't check it because he doesn't have an oscilloscope etc. I have my meter but not sure of where to set it or where to test.
Old 06-17-2022, 08:46 PM
jbattles's Avatar
jbattles
i am going to be honest i don't you to get hurt. there's not much in the vert section. 90 percent is in the output chip. i hate to say the parts cannon, but you half deflection and the bottom has a nice picture, so do not give up. the tough dogs are more rewarding to fix. there's about 10 parts in the circuit. you replace the 3 caps and has the pulse from fbt. cap from the ic was replaced and the 3rd was to. that's the next thing other checking resistors and diode.
Old 06-17-2022, 09:26 PM
Stuck in the past
Going at this one piece at a time, what should I check next?
Old 06-18-2022, 09:44 AM
jbattles's Avatar
jbattles
check diode 14501 the resistors download the service menu a look at page 43 shows the whole section. it has to be the output replace that.
Old 06-18-2022, 06:37 PM
Stuck in the past
Ok I found the cr14501 right next to the caps we replaced. I have trays full of new diodes. Is there a specific number or something I need to look for yo get a match?
