Old 01-26-2021, 12:45 PM
I still maintain that it's an oil cap.
Consider the Zenith safety cap used in the 25FC58 or so. The original American Radionic cap. When I replaced them, I would take the hammer to them to see what caused them to fail. There was a oily film to the inside.
I never smashed the orange Spragues, as the were always good.
Let's see here... crypt scribbling on the lower right corner, shedded pieces of wax from a dying cap, 3 paper cap (bombs), that are screaming to be replaced, , a soldering iron accident with the blue wire on the lower left corner, and what seems to be magnet wire very close to a metal chassis,
but, that's just a guess!
Old 01-26-2021, 11:57 PM
rca21d645 rca21d645 is offline
So I have the picture looking pretty good but the audio is now quieter and there's a loud hum drowning it out. I think it has to do with the vertical because turning the height and linearity controls makes the hum quieter.
Edit: upon further inspection it appears the audio output tube had gone bad between now and when I started this project, as the emmissions now test bad.
Old 01-27-2021, 12:34 PM
The voltage on the cathode of the audio output(pin 1) supplies 135v to the audio IF, tuner, video IF, and video out circuits. Basically the tube is used as a b+ dropper to supply the lower b+. If you operate the TV with the audio output tube pulled, those other circuits will loose their b+. Good to verify that 135v volts is in the ballpark.
Old 01-31-2021, 05:46 AM
I finally figured it out, one of the 6AL5 tubes wasn't making a good connection in its socket, and after moving it around a bit the audio comes in just fine.
Old 02-01-2021, 01:13 PM
That is why cleaning all tube pins and sockets is one of the FIRST things that I do in any restoration.
Regards,
Phil Nelson
Phil's Old Radios
Old 02-01-2021, 04:44 PM
compucat's Avatar
compucat compucat is offline
1949 Motorola 9VT1
Regards,
Phil Nelson
Phil's Old Radios
I had a problem with my Zenith 25MC33 color roundie where it looked like the horizontal AFC diodes had failed, classic symptom. I replaced them only to find the problem was a dirty socket for the horizontal oscillator tube.
Old 02-04-2021, 05:05 PM
The new picture tube arrived today, and after installing it the picture looks great. I have full contrast and the brightness works fully with a nice sharp picture. It looks a bit dim in the photo because it was in a well lit room at the time.
Old 02-04-2021, 05:14 PM
Good deal. And that has got to be about the roundest test pattern one could expect , which means you have it adjusted perfectly.
Old 02-04-2021, 07:06 PM
I'm glad it worked out for you!
It was quite a hassle. First the power transformer, then the vertical output transformer and all the rest of the parts and work that was involved.
