Old 05-27-2020, 10:35 AM
sampson159's Avatar
sampson159
stunning pictures!i cant believe how beautiful it is.well
done!
Old 05-28-2020, 08:50 PM
Thank you. Just want to add that all 27 images were taken with the same setting. The movie has a wide range of lighting conditions from outdoor, low sun angles too low light indoor scenes.
Old 06-23-2020, 02:57 AM
colorfixer's Avatar
Originally Posted by Josef View Post
Nice, but I would j hook the copper wire to make the connection long term stable. In your case it could be better not to touch the connection any more to avoid further damage. I usually clean flybacks (from our european b&w sets) with WD40 to protect them from moisture and soften dried out isolations. Take care if there are carbon track pots and don't use WD40 in this case.
I would be really afraid of using something as explosive as WD40 near anything high voltage or capable of arcing.
Old 06-23-2020, 09:45 AM
WD40 isn't explosive as an applied coating...heck it won't even explode if you shoot the spray through the flame of a lighter as I have done... It'll just burn energetically and give you a nice flame thrower for toasting jumping spiders.
Wet WD40 isnt that easy to light either. Many years ago I was trying to fix a 30s fan that I eventually found had a bad contact brush and it was arcing like crazy but not easy to keep enough WD40 on the rotor to sustain burn for more than a couple seconds.
Old 08-15-2020, 11:33 AM
Deleted. Posted in error.
Old 08-15-2020, 11:38 AM
WISCOJIM WISCOJIM is offline
Atten Moderators, I noticed that posts #78 and #79 are not related to this thread and should be deleted. Thanks.
Don't they relate to the posts leading up to post 39?
Old 08-15-2020, 11:43 AM
Your correct. I will cancel request. Thanks for pointing that out.
