Old 07-19-2020, 02:59 PM
pac.attack76's Avatar
Stuck in the past
1975 RCA XL100 model CU 680 W trips reset button when turned on
Red reset button trips when power knob is pulled out. Reset and does it again. Where should I begin looking? Interested in fixing up and using with Atari games.
Genesis does what Nintendon't
Old 07-19-2020, 08:50 PM
damen's Avatar
damen damen is offline
Remove the power supply diode board, reset the breaker and see if it holds and the channel light comes on. If it does, check all nine diodes on the little board. If diodes all check good then there's a short on one of the B+ supplies. Large filter cans, vertical or horizontal SCR issues were common. Can remove the SCR mounting screws to check them without actually having to pull them out of their sockets.
Old 07-20-2020, 07:29 AM
Stuck in the past
Sounds good, I'll check it out soon as I can get around in here. I've got stuff scattered everywhere.
Old 07-20-2020, 07:34 AM
JohnCT's Avatar
JohnCT JohnCT is offline
If you find a shorted diode, change the other three in the same bridge grouping. I believe there are two full wave bridges on that small card, plus another diode that never shorts.
Those are standard recovery diodes, so any typical rectifier like the ECG 125 will work fine.
John
Old 07-20-2020, 07:44 AM
Stuck in the past
Great, ty🙂
Old 08-26-2020, 06:50 PM
Stuck in the past
Restoration begun on this set. I've managed to get the entire outside done. Now if I can ever get inside and begin with repairs.
Old 08-26-2020, 07:34 PM
JohnCT's Avatar
Is that the model with those miserable little sliders behind the door?
John
Old 08-26-2020, 08:00 PM
dishdude's Avatar
dishdude dishdude is offline
Cabinet looks great.
Old 08-27-2020, 08:12 AM
Stuck in the past
Thank you. Yeah it has the 4:sliders for contrast, etc.
Old 08-27-2020, 04:00 PM
JohnCT's Avatar
The controls are usually good, but those little chromed plastic sliders like to break. If you have to adjust them, try to push them at the base of the slider instead of using your fingertip at the top of the slider. Takes the torque off them.
I used to buy them 50 at a shot back in the day.
John
Old 08-27-2020, 06:44 PM
Stuck in the past
These are still intact and move without a problem. I'll still watch out for them. Can't wait to get this up and running. I plan on using Atari games on it.
Old 09-01-2020, 06:42 AM
60s Throwback
Very nice set.
Old 09-01-2020, 07:24 AM
Stuck in the past
Originally Posted by consoleguy67 View Post
Very nice set.
Ty🙂
Old 12-17-2020, 10:10 AM
Rog Beltmann Rog Beltmann is offline
If power supply checks ok don't overlook the trace/retrace SCRs
Old 12-17-2020, 11:34 AM
Stuck in the past
Ok👌
