Old 04-27-2020, 09:08 PM
Schanz's Avatar
Schanz Schanz is offline
Pioneer Stereo Fan Club
My Crosley 50
Found locally on CL. Excellent condition. Comes with the original headphones. Neatest thing (to me) is that it comes from the original family. Supposedly a descendant of Leon Foucault for you science geeks. Not sure I understand yet the voltages or how to tune it but that leaves some fun to be had.
Looking for a dial glass and knobs for a R-30s Fisher console.
Old 04-28-2020, 12:13 AM
Titan1a Titan1a is offline
Book capacitor. Designed efficient and inexpensive.
Rick (Sparks) Ethridge
Old 04-28-2020, 04:38 AM
decojoe67's Avatar
Very nice find. I have the ACE V, which is basically the same set. If it has a good original brass-based UV-200/201, you just hook-up a lantern 6V battery for the A supply and 3 transistor 9V's snapped together for the B supply. As far as tuning, you can't go wrong. Just fiddle with all front controls. Usually the filament voltage (arrow knob) needs to be up fully. I use my transmitter, so antenna is not a problem, but it will require a long antenna to tune in stations.
Old 04-30-2020, 05:45 PM
Josef's Avatar
Josef Josef is offline
Interesting:
I have never seen or heard before about such a capacitor. Seeing it in opened position would be great.
BTW: This will be one of the first radios which turn 100 in 4 or 5 years
Old 04-30-2020, 07:02 PM
Schanz's Avatar
Here's a closeup. Insulator sheet appears intact
Old 04-30-2020, 09:07 PM
Schanz's Avatar
Before I add power to this, I want to be sure I have the power correct. I run the B- to the same post as the A+ ? B being the high voltage?
Old 04-30-2020, 10:01 PM
You run B- to whichever A terminal doesn't have the filament adjustment resistor.
You need 500 ohm or higher headphones or speaker for it and you connect the phones/speaker between the speaker and B+ post. 20s sets didn't use output transformers to match impedance (though you could do that with it now) and instead used high impedance phones/speaker.
Old 05-02-2020, 07:00 AM
decojoe67's Avatar
This PDF file has '20's radio hook-up diagrams including one for yours. Just scroll down to it:
http://arbeiii.com/ARBE-III%20Compil...20Diagrams.pdf
