Old 12-24-2019, 04:03 AM
LADR's Avatar
LADR LADR is offline
Местное и дх радио
1968 Motorola TS-592
Got this set off of Letgo a few weeks ago. It’s all SS except for the HV rectifier. It has instant bake with no on/off switch, so the crt is down a bit, and blooms when the brightness is turned up too much. Besides that, it works great.
File Type: jpg D99BBF2B-86BE-453D-8CE3-F0DB7C95089C.jpg (75.0 KB, 46 views)
File Type: jpg 5F1F8FB4-CFBC-4116-AEF6-88A91F63FEBE.jpg (94.4 KB, 42 views)
File Type: jpg 537EC944-0645-45F9-A3CC-7344D4D7F323.jpg (75.2 KB, 45 views)
Your good times will bring me down
Old 12-24-2019, 11:48 AM
I wonder if this was one of the chassis I worked on at Motorola, doing arc tests. There was a failure mode where a CRT arc to G1 would couple through the vertical retrace blanking cap, through the vertical output transformer, into B+, into the audio output, and then kill the audio driver transistor. First fix was to put a small choke coil in the audio output base lead, I think. Final fix was to change the audio driver transistor to a more robust part.
I can remember the feel of those small front knobs with the square hole.
