Old 01-28-2019, 12:08 AM
mr_rye89's Avatar
mr_rye89 mr_rye89 is offline
Blonder Tongue AM60-450 Intermittent?
So I was using said unit and it randomly quit transmitting after about an hour of use. The lights on the unit were still on despite it not transmitting. the next day I plugged it in, it worked for an hour and did the same thing.
I have two of these AM60-450 units, one that I re-capped/put new regulators in the power supply and one I haven't yet. So I swapped the PSU from the intermittent unit to the "unrestored" unit. It's been working great for several hours......
Anybody here have their BT modulator quit randomly?
Old 01-28-2019, 10:46 AM
Did you cut a half wave dipole to the transmit frequency? If you didn't and the current antenna is reflecting most of the power back into the BT you could be tripping a protect circuit... especially if the output is cranked.
Been a while since I opened one of mine but if any heatsinked semiconductors exist the thermal paste could have expired.
Also there's lytics in the TX section too... those are not above failure.
Old 01-28-2019, 09:29 PM
mr_rye89's Avatar
Hmmm I didn't think of thermal protection circuits. My antenna is a set of small DTV rabbit ears. I tried a tuned dipole but it didn't perform well. I might try building another one.
Would it be a good idea to use a 75 to 300 ohm balun or just terminate straight to coax?
Old 01-29-2019, 11:00 AM
I followed this video with the exception of using that fancy meter http://www.youtube.com/watch?v=z4dhRt7tmd4
I can send a block radius with this setup. The percentage length he removed to tune it should apply to and channel.
