Old 02-02-2015, 03:56 PM
Visual's Avatar
Visual Visual is offline
Output. "Sound multiplex
Question I looking for all modell numbers on the Pioneer rcvr+AM stereo out jack
https://www.youtube.com/watch?x-yt-c...tailpage#t=344Pioneer SX-4;5;6;7;8;9
SX-60
SX-V80
SX-720
SX-3700
SX-3800
SX-D5000
http://www.oaktreevintage.com/SOLD_R...rs_PIONEER.htm SX-D7000
SX-3900
...SO-my question is.....were is the same tese FACTORY am stereo adaptors;or even prototypes....
VS-680VPT /HRS9000EG/!!\A-GX1/!\HR-Z1
Old 02-02-2015, 04:14 PM
Radio (s)hack sold AM stereo tuners....By the time AM stereo came out aside from perhaps hobby kits there was not market for AM stereo adapters since most consumers were tech illiterate by then.
Old 02-02-2015, 09:36 PM
Visual's Avatar
whatt hapen abaut japanese models is curiose on the same rcvrs-am st.out jack is on place,or noth
Old 10-06-2015, 09:29 PM
KentTeffeteller's Avatar
Gimpus Stereophilus!
Likely not available to you easily. If offered at all.
Old 12-02-2015, 12:54 AM
I know its not Pioneer.I found a Delco AM stereo/FM stereo cassette at the fleamarket years ago cheap.I modified it with line outputs before the volume control with coupling caps. I can direct feed my digital recorder with no overloaded signal.
I do enjoy those Super tuners they made.
Old 01-20-2019, 06:17 AM
svhs's Avatar
svhs svhs is offline
DIGITRON
Thumbs up
HERE example
And in JAPAN is wide use am stereo
https://translate.google.co.jp/trans...Fst-gt550.html
https://translate.google.co.jp/trans...27508;史
Old 01-20-2019, 10:33 PM
Titan1a Titan1a is offline
There once was a CQUAM adapter for these and other brands of receivers on Ebay. I still have one.
Rick (Sparks) Ethridge
Old 01-24-2019, 04:53 AM
svhs's Avatar
DIGITRON
Cool
am stereo ALERT
https://www.worthpoint.com/worthoped...o-fm-136441406
a Marantz SR-940 that I've owned since new (Jan 1986). These receivers were manufacturedfrom 1984 to 1987 using the Motorola MC13020 C-Quam AM Stereo decoder chip. Note that the similar Marantz SR-440, SR-640, and SR-840 receiver modelswere designed for AM Stereo but were sold without the necessary AM Stereo decoder module installed. This module, called the "AMS40", could be purchased from a Marantz dealer in order to add true AM Stereo capability to these models. The SR-940 came in three colors: black, silver, and gold.
There are NO missing switches or knobs. It is working and complete. It also comes with two working RMC-40 remote controls, the original "Handbook of Instructions", and two gold Marantz warranty sheets. The only thing missing is the AM loop antenna. It has A and B switches for A channel and B channel speakers rated at 100w per channel.
The whole reason I purchased it was because it had the AM Stereo feature built-in. I remember listening to a local talk radio AM radio station at the time where they had the "liberals on the left" channel and the "conservatives on the right" channel. It really felt like I was sitting between to people on either side of me talking!
https://youtu.be/QsX2e1kLb98?t=4017
Sony ST JX520A
hi
i am
Visual
Old 02-19-2019, 10:32 PM
svhs's Avatar
DIGITRON
Thumbs up
http://rf-circuit-schematic.blogspot...r-mc13028.htmlhttp://www.aspisys.com/dqam.htmThis electronic circuit is AM stereo decoder that accepts the signal from the IF of a receiver (450 or 455 KHz) and decodes stereo medium wave broadcasts.
It operates at 8-15VDC and provides standard level left and right audio output for direct connection to the audio amplifier.
It may be used to support 30Hz-15KHz audio but it depends on the bandwidth of the receiver's IF.
Read more: http://rf-circuit-schematic.blogspot...#ixzz5g2Skh9Xdhttp://meduci.com/Rich Modafferi built his "connect to any radio" AM stereo decoder enclosure to house his meduci AM_ST decoder board, which complements his tube-based AM stereo C-QuAM transmitter. Rich also used his Sencore SG80 stereo generator for testing purposes. His enclosure has inputs for 455 kHz I.F and a level control is provided for adjusting this I.F input. There are both BNC and RCA I.F input jacks, and fixed and variable audio level outputs. Single indicator lamp functions for "power" and "stereo", glowing dim on power, and full bright for AM C-QuAM stereo lock.
hi
i am
Visual
