Old 12-20-2018, 04:55 PM
Skywaffle Skywaffle is offline
Questions regarding broken CRT lead
Hello,
I have been working on an RCA CTC-20C which started with a mostly dead CRT (among other issues). After some time on the rejuvenator, the CRT was able to produce a fairly good picture overall. This became short lived when I decided to work on the chassis some and afterwards would not get any neck glow. Upon de-soldering the bakelite base, I noticed that one of the leads had broken off mostly flush (somewhat recessed) to the glass.
Has anyone encountered this type of issue before? If so, has anyone found a way to repair this type of damage?
Thanks,
Matthew
Old 12-20-2018, 05:41 PM
If it is recessed things get difficult.
I'm guessing you lost a heater lead. If it was not a heater lead you could probably use conductive glue, but the heater draws a lot of current and odds are conductive glue won't survive that...
If the glass is reasonably thick around the lead and there's a raised bit of glass wrapped around the lead stub then you may be able to expose a solder able nub by grinding the glass down with a small gentle dremmel grinding bit.... but grind too far and you loose vacuum. Also you have to apply heat with the soldering iron for the shortest possible time needed to get a solder joint....too long heating it and the glass will crack and the vacuum will leak... grinding the glass will also make it more prone to cracking.......
What you have is a game of finesse, speed, judgement and luck with the future of your CRT on the line....No pressure.
Old 12-20-2018, 06:49 PM
What a heartbreaking experience. I will try to clean up the area and see if I can expose any of the wire. It appears that there is a bit of oxidation at the base of all the leads.. But only the one managed to break (or maybe burned up; the glass stub you speak of that can be ground down is chipped.)
Going into the project, I initially never had much hope with the initial condition of the CRT. But things were really looking positive after the rejuvenation. It was a joy to watch for the brief time I could.
Old 12-20-2018, 07:53 PM
I agree with Electronic M's assessment of your situation. I hate to say this, but unless you can find some way to expose enough of the broken lead to solder to it (not likely, given how short it is), and the very real possibility of ruining the tube if anything goes wrong while you are working on it, your CRT is junk and must be replaced. I would try to find a good used CRT from a junked set. In this age of flat-screen TVs, it may not be easy to find a replacement for any size CRT, as these tubes are becoming very scarce and are all but impossible to find new--needless to say, no one makes CRTs anymore. I am not familiar with the CTC20 chassis, so I don't know if it uses a round or a rectangular CRT.
Further, if you rejuvenated the tube with a CRT tester, bear in mind that any improvement you may notice won't last long, so it is probably just as well that you will have to replace the tube. Rejuvenation is usually done only to restore a CRT to usable condition (albeit dim) until the tube can be replaced; it is not meant to be a permanent fix. The tube will eventually dim again, at which point it must be replaced. CRT brighteners were often used in the 1950s-'60s to extend the usable life of dimming tubes, but again, this was only a stopgap measure and usually resulted in a dim CRT again within months; the only solution in this case was either to replace the tube or the TV.
Old 12-20-2018, 10:35 PM
See reply #218.
http://www.videokarma.org/showthread...master&page=15
Old 12-21-2018, 11:14 AM
This tube is a round 21fjp22. The TV had a brightener on it when I had acquired it, but would not produce much of any kind of image initially. On the tester none of the guns would show any readings until the rejuvenation was performed. The difference afterwards resulted in a picture that was very impressive in a lit room (compared to an extremely dark unfocused looking picture in a dark room). I suppose I had hoped maybe this would be a fairly long term fix.
Old 12-21-2018, 11:46 AM
dtvmcdonald's Avatar
If it is not the heater conductive glue will work fine.
If you are afraid of overheating to solder, get some pure Indium wire off
ebay and use that as solder, using ordinary liquid flux. It melts at just the
right temperature, solders easy and won't melt with ordinary base heat. Indium
can't hurt ... its a good solder and sticks well to copper, steel, other tube pin
alloys, and ordinary solder. I've even had good luck soldering to germanium with it!
Use a small wire and glue down to the glass after soldering.
But ... I've had good luck with regular solder and a tiny tip on both CRTs and
a very rare iconoscope.
Old 12-21-2018, 12:20 PM
BTW if a CRT has not been used for a few years the cathode will act as a getter and that will coat the emissive surface in crud that blocks emission....we call it the CRT falling asleep. When a CRT is asleep a rejuve is a dangerous way to wake it up (you can burn off the emissive surface along with the crud covering it). The best way to wake up a CRT is to let it sit on the tester in emission mode for as much as an hour ( check for improvement every 15 min) if it doesn't Improve or barely improves increase the.heater voltage to 1.4x it's designed value and repeat the process, THEN if there's still no life or much less than a usable value you can try a rejuve.
Rejuvination is risky use all safer measures first.
Old 12-21-2018, 01:21 PM
Agree 110%. Rejuv only after all other measures (including CRT brightener) have failed. Learn't that the hard way many moons ago.
Old 12-22-2018, 01:12 PM
Old 12-22-2018, 01:29 PM
I have used silver-filled (i.e., conductive) epoxy to repair a similar problem on a CRT base:
https://antiqueradio.org/CapehartFar...airingTubeBase
Phil Nelson
Phil's Old Radios
Old 12-22-2018, 02:17 PM
But is silver epoxy conductive enough to repair a lead that carries heater current in a 3 gun color CRT (1.8 amps nominal, and much more at cold turn on) ?
Old 12-22-2018, 03:38 PM
Don’t know offhand, but this page has some specs:
https://www.mgchemicals.com/products...ive-epoxy-8331
Phil Nelson
