Old 03-14-2016, 11:46 PM
Sony's VCA-4 automobile television antenna is a weird one. I guess it worked great when you were travelling but unless you had antsy kids in the back, wouldn't it be a little hard to watch?
I put magnets in mine so I can stick it to my car's ragtop. Officially the last guy in town doing that.
Old 03-16-2016, 09:23 AM
DavGoodlin's Avatar
Motorola Minion
Probably worked better than those boomerang jobs
especially on VHF.
-Dave G
Old 06-17-2018, 11:31 AM
Old 06-17-2018, 11:40 AM
Ed in Tx's Avatar
Ed in Tx Ed in Tx is offline
Zenith Walton My 1st TV
Judging from the length, it looks like a low band VHF 2-6 Yagi with two folded dipole driven elements, probably to spread the useful frequency range.
Old 06-17-2018, 12:15 PM
Looks that way. Having each folded dipole very near a dipole element is one of the wackier things to me, but I'm not an antenna expert. Maybe just a way to transform 75 ohms to 300? I wonder how efficient this was?
Old 06-17-2018, 12:52 PM
Ed in Tx's Avatar
It would be interesting to plug the design and dimensions into some modern day antenna modeling software.
Old 06-17-2018, 01:04 PM
I think that the extra element is connected correctly on the foreword driven element... screwed to the center of the bend. I would guess that the rear DE has holes for similar attachment of the extra element.
IIRC, some marketing people dubbed this a "NEW, IMPROVED TRIPOLE DESIGN" ... Supposedly improved the impedance matching of the two DEs to 300 ohm line.
Old 06-17-2018, 01:11 PM
Titan1a Titan1a is offline
I had the same kind of RS antenna on a rotator. I got up to 175 miles reception. I lost it and would give almost anything for another.
Rick (Sparks) Ethridge
Old 06-17-2018, 03:21 PM
Old 06-17-2018, 04:53 PM
300 ohm twinlead will give you the perfect chance to resurrect another 1950s practice: aluminum foil wrapped around the line and sliding back and forth to tune/detune any mismatch. Of course, you cannot get the fine feedback with digital that you could with analog.
I was so happy when they got rid of that stuff. Prone to picking up local motor interference, and needed to be spaced away from metallic antenna support structure. The town house I moved to in 1974 had a pre-installed VHF folded dipole in the attic, with twinlead of course, to a living room antenna outlet. Couldn't understand why it was SO lousy until I traced the twin lead and found it was routed through the wall by wrapping it around a convenient electrical conduit.
Old 06-26-2018, 08:19 PM
mr_fixer's Avatar
mr_fixer mr_fixer is offline
Hi All, i'm a little late to this party, but i thought i would post a pic of my 60's UHF twin bow tie antenna that i still use today.
Old 06-26-2018, 10:05 PM
Actually a pretty reliable antenna. When we compared indoor antennas for digital reception, this one was surprisingly OK, coming close to the "Silver Sensor" log periodic design. I don't have enough intuitive antenna knowledge to explain why that is so, with the reflector so close to the active elements.
Old 06-27-2018, 11:25 AM
A friend of mine uses one for DTV even now.
Old 07-10-2018, 12:27 PM
Yes, I would like to hear why some reflector style antennas end up with only about 1/10 to 1/8 wavelength spacing between the driven element and the reflector.
I have built several of the biquad antennas, and indeed they seem to perform best with short reflector spacing.
http://martybugs.net/wireless/biquad/
https://buildyourownantenna.blogspot...alculator.html
Old 07-13-2018, 03:25 PM
DavGoodlin's Avatar
Motorola Minion
Radio shack sold that one for $3.99 see WiscoJim's post link to catalog #60. If you lived in a high-rise apartment, it was way better compared to any other indoor UHF antenna.
Many apartments had only VHF-only MATV systems, and that little wonder usually pulled in at least two of the three Philadelphia independent UHF stations, provided you were up a story or two and facing the right direction.
-Dave G
