Old 08-30-2017, 03:49 PM
Adam's Avatar
Adam Adam is offline
Zenith VR-9000W1 beta VCR
This was my other Wisconsin radio meet find. I finally found a beta tape at a thrift store (they only had 1 stuffed in with the vhs tapes!) After messing around with it a bit to unstick things, it will load the tape, rewind and fast forward. When I try to play the tape, it starts to do it for a few seconds, eats the tape a bit, then stops.
Assuming that I can fix this by just swapping belts and maybe idler tires, where can I get them for this? Also are all the belts accessed from the top? I don't want to bother taking it apart from underneath if I don't need to.
Old 08-30-2017, 06:57 PM
Findm-Keepm's Avatar
Followin' the Rules...
Anyplace that sells or has PRB belts:
PRB Belts: SL4.0, SE10.5, SB11.7, SC11.8, SF14.6, FB11.2
Tire: T925
Pressure Roller: VPR5
Russell Industries - home of PRB Belts / EVGame Belts
http://russellind.com/prbline/index.html
MAT Electronics may also have them
https://www.matelectronics.com/belts-kits/
Electronix has thinned a bit:
http://www.electronix.com/dvd-vcr-re...5_440_451.html
Brian
USN RET 22YRS (Avionics/Cal)
Old 09-01-2017, 03:01 AM
MX70's Avatar
MX70 MX70 is offline
Zenith Beta VR 9000 W
I'm certain that this VCR has the same mech as the Sony SL 5400 I used to own about 20 years ago. IIRC, the idler, pinch roller and counter belt are accessed from the top, everything else from the bottom (capstan, reel belt etc.), just undo one (2?) pcb's underneath and the mech is all there.
Max
