Old 08-19-2016, 10:01 PM
Thanks guys for the insight on dating when the TV was serviced!
Old 08-19-2016, 10:04 PM
Since this has gone from a "set for sale" thread to a repair thread I decided to move it to this forum. I left a redirect for one week so everyone can find it.
Old 08-19-2016, 11:37 PM
Radiotronman's Avatar
Radiotronman Radiotronman is offline
I have this set too. Very thick Bakelite and heavy as can be. Mine is actually a copper plated chassis. Chassis 20T1. I also have the 14" console to match. Extremely well made and great sets once restored.
Old 08-20-2016, 10:19 AM
Eric,
Thanks for the relocation. I was going to shut down the For Sale thread and start a restoration thread.
Old 08-20-2016, 10:20 AM
I'm looking forward to restoring this TV. This is my first Admiral and you're right. The cabinet is stout!
Old 08-20-2016, 11:32 AM
kvflyer kvflyer is offline
An Admiral, like the one you have, will respond very well to new components. It is very rewarding when you apply power and it just works.
Good luck, please make sure to document and post pictures.
Old 08-20-2016, 11:36 AM
Just to let everyone know, this set uses a 14CP4 CRT. It is a model 14R12 with a 20T1 chassis. Brown Bakelite cabinet.
Old 08-21-2016, 12:54 PM
I misquoted the CRT type number as a 14CP4. Must have been thinking of a 17BP4. I was right with the model and chassis number, per Riders eight.
This model doesn't use the audio output, as the voltage divider, like the 20Z1, a year earlier.
Old 08-21-2016, 01:47 PM
I think you said 14BP4 in the classifieds post. Looking at the specs for 14CP4 and 14BP4 they look very close. Both spherical faces I believe.
Old 08-21-2016, 08:51 PM
Poor proof reading again! I meant 14CP4. I knew, there was a 14BP4, RCA used a 14EP4, which is similar. It all depended on the manufacturer, who made the tube, which number they assigned to it.
It's probably 50 years ago, since I bought and installed one.
Old 09-17-2016, 07:19 PM
Today I started on the restoration for reals. I again checked the CRT on my BK 467. All I could get is a .45 reading. Still into the red even after about a half hour. I then decided to try it in my 16" AMC TV. So I swapped the CRT's and the 14" gives a decent picture. Now it was a little out of focus, but it was bright enough! My shop is well lit and the picture showed up real good with all the lights on. So I'm proceeding wit the restoration.
Next up is to check the transformers and coils etc.
Old 09-17-2016, 08:09 PM
Earlier in this thread, there was a discussion on the CRT. It looks like it is a replacement. It has not been rebuilt. It is a CBS Hytron 14CP4. I couldn't read the date code.
This CRT has 2 getters. One on each side of the neck between 2 bands of the internal aquadag.
I'm including some pictures of the label and what the getters look like.
Old 09-18-2016, 09:32 PM
After a good look over, I pulled the HV rectifier tube and the lead off the 1B3GT tube then powered up the chassis using my variac and meters. No problems and all the tubes lit up. I used my meter to check the HV rectifier and 1B3GT tube heaters. All checked ok.
Old 09-19-2016, 09:11 AM
Why did you pull the 1B3 ? No harm is gong to come from leaving it installed.
Old 09-19-2016, 10:37 AM
You're right. Seeing the rectifier tube was pulled. Just being overly cautious and still being new to this.
