Old 08-02-2016, 05:41 AM
12at7 or 12au7
Does anyone know which tube 12at7 or 12au7 has more gain.
Old 08-02-2016, 09:21 AM
The 12AT7 has a higher mu, therefore higher gain. The circuit should be designed around it.
Old 08-02-2016, 09:59 AM
They are for the pilot tv so I was wondering why it don't have all that good of sound and picture, I have 12au7 in there so I'm sure it will improve with the right ones, it was designed for the at7 s.
Old 08-02-2016, 10:28 AM
I had to look at the schematic, the set uses three 12AT7's. The 12AU7, never did make a good tuner tube. Even if you have a 12AT7, that's a little weak, it's still better than using a 12AU7.
Once in a while, the tube sub guides, can lead you down the wrong path.
Old 08-10-2016, 08:37 PM
Olorin67 Olorin67 is offline
A 12au7 has a gain of 20, 12AT7 is 70, very different tubes. Surprising it works at all with the wrong one. 12ax7 is closer to the AT7, with a gain of 100.
