Old 07-25-2016, 05:49 PM
Still looking for some information about hooking up a frequency meter to measure the Horizontal Frequency of 15750 cps. Has anybody done this?
Thanks.
Old 07-25-2016, 08:03 PM
I've got the test pattern looking pretty good. There is a "ghost like" squiggle on the right side. I haven't played a DVD yet but I will.
Old 07-25-2016, 08:36 PM
That squiggle looks like a bit of H. retrace. See if it'll go away by reducing the brightness a bit.
Linearity that good (both H and V) is seldom seen on a vintage set. The quality of your resto would do a seasoned techie proud.
Old 07-25-2016, 08:44 PM
Wow, thanks old coot88!
And here is a short clip from Veggie Tales. I'm pretty happy with the results.
https://youtu.be/ht_zN7l4fSo
Old 07-25-2016, 09:47 PM
WISCOJIM WISCOJIM is offline
You should be. Excellent restoration. Thanks for sharing it with us.
Old 07-25-2016, 10:09 PM
Thanks Jim.
Old 07-27-2016, 01:43 PM
I was just reviewing the entire thread and came across the discussion about the number of IF stages this TV has (2). Looking at the picture after replacing the caps and resistors, and some tubes, looks like Phil was right about it not mattering so much now-a-days.
Good call Phil.
Old 07-27-2016, 08:42 PM
When you are connecting a DVD player, VCR, or other non-over the air source, it's as if you lived two blocks from the TV station in the old days. No need to amplify a signal that's already strong and free of interference.
Phil Nelson
Old 07-27-2016, 08:54 PM
Wow, that looks great, now you just got to get the color working...
Seriously though, you did a nice meticulous job restoring that chassis.
Old 07-27-2016, 09:38 PM
Phil Nelson
Yep!
Old 07-27-2016, 09:39 PM
Thank you.
Old 07-29-2016, 09:45 AM
Time to do the knobs. These came with a lot of white gunk on them. What can I use to clean them? I remember Bob Anderson talking about this in 1 of his videos but can't remember which one.
Also I have to polish the bright brass centers. After that I'm thinking of spray painting some clear over the knobs to preserve them.
Old 07-29-2016, 12:24 PM
I cleaned and polished the brass brights on the knobs. To polish the brights, I used some Mothers and then Gorhams silver polish. I cut a Q-Tip in half and chucked it up in my drill press. Then I added some compound then polished the brights. I went through several Q-Tips for each knob. When done. I did a little hand polishing with a soft rag and Gorhams to even out the shine.
Old 11-17-2016, 01:40 PM
Time to repair the cabinet.
I patched in some mahogany veneer in the chipped out places. These were all on the one side.
After sanding them smooth, I added some grain filler which is drying right now.
Old 12-03-2016, 02:49 PM
It is done!
