Old 04-23-2016, 09:23 PM
RCAZenith RCAZenith is offline
What is that on the jack panel?
Kind of looks like a "plug" end of a coax cable that would normally go on a 75 Ohm post. This was on one of the sets at the rummage store today.
Sent from my iPhone using Tapatalk
Game Room TV's:
1997 RCA Colortrak 27" Console
1987 Zenith 19" V3912W
Old 04-23-2016, 09:30 PM
rca2000's Avatar
rca2000 rca2000 is offline
I think you are supposed to plug it into the coax jack on the panel...when you are NOT hook9ng to coax cable. Otherwise...you hook your coax cable TO that line..
Old 04-23-2016, 10:09 PM
We can't see it due to photo quality, but what does the label right beside the jack say?
Could be a loop-thru output to a VCR (after internal 300 to 75 ohm conversion).
What is the other cable -- the one without the white stripe?
Chip
Old 04-23-2016, 10:10 PM
Yep, that's what it is. When you're connecting 300 ohm twin-lead, you plug the pigtail coax plug into the hole and that connects the 300 ohm terminals in the circuit.
Old 04-24-2016, 08:10 AM
So it's an output to the VCR, then?
That makes sense. It saves about 2 or 3 transformers to go from 300ohm to 75 and thru the VCR and back to 300 for the tv.
Game Room TV's:
Old 04-24-2016, 08:54 AM
NO the short coax goes direct to the tuner. If you are using
ears or other 300 ohm for VHF you plug the coax into the
hole & use the screws. Its just part of a matching transformer.
Very common arrangement, sometimes use jumpers also.
Old 04-24-2016, 11:41 AM
I see. Somebody probably removed the jumper years ago and lost it.
Game Room TV's:
Old 04-24-2016, 10:57 PM
dishdude's Avatar
dishdude dishdude is offline
The short coax is hanging down out of the picture on the left. It's a late 80's Panasonic.
Old 04-25-2016, 07:25 AM
Oh I see it now. Thanks! All of the tvs I have owned have either been coax only or twin lead only. I have never had one with a mix of the two. The late 80s must have been a confusing time for televisions!
Game Room TV's:
