Old 04-09-2016, 10:24 PM
reichsrundfu reichsrundfu is offline
Thought I would post an update regarding the apparent design flaw in the 50T-701 & 702 chassies which causes the HV to drop off after the set has been playing and gets hot. In my set, I have noticed that the picture will gradually get darker and after about 2 hrs I will notice the picture size bloom slightly, indicating that the HV is dropping off. Although the set is still watchable, I decided to think about preventing the condition from occurring without replacing the entire HV section.
I installed a 3 inch cooling fan to the back cover of the HV cage by drilling a 3" hole in the rear cover and mounting the fan on the cover directly across from the transformer which is apparently the offending component. The fan is so wired that it turns on when you turn on the set and off when you shut it off. After more than two hours, there is no - zippo - visible drop off in HV. There is absolutely no dimming of the picture, or any blooming of the picture, nor any loss of focus or sharpness. The airflow is pushed into the HV cage where it keeps the transformer and other components cool, and then flow up and out through the ventilation holes at the top of the cage, whereupon it reflects off the inside top of the cabinet and back down again so it helps keep all of the chassis top components cool.
The fan i used is a generic 3" (3100rpm) 117 VAC fan I picked up at Radio Shack. The fan is audible, but its not bad nad not annoying or for that matter much noticeable. The big benefit is that the TV is now a nice, reliable steady daily player. This seems to be a very viable solution to a well known problem!
-George-
Old 04-10-2016, 12:20 AM
Nicely done!
Old 04-15-2016, 10:19 AM
Nice that it worked, but I really suggest avoiding cutting a hole in the original back and HV box
Old 04-15-2016, 02:11 PM
Well that would have been great but unfortunately there was no space to mount the fan without doing so. The alternative was to eliminate the rear cover altogether which I felt was a worse option. That all said the set plays well and you can actually watch a whole two hour program on it and that's with the original HV in it. (Assuming of course eyestrain over watching a big, luxurious 7 inch screen doesn't s in first) !!
Old 04-15-2016, 04:39 PM
You could have made a new back from some masonite and preserved the original. I'm not trying to give you a hard time just some friendly advice. Many collectors prefer originality.
