Old 02-10-2016, 10:33 PM
The 1965 Motorola "Cadet" Portable TV!
Here is a 1965 Motorola "Cadet" 12" portable TV which uses the TS-454 chassis. This is the very first generation for this particular cabinet design with the handle on the side. This particular set is housed in an attractive "Mandarin Orange" cabinet which I have not seen until acquiring this set. I have the original 1965 Motorola product technical training manual for this set and it lists this particular model with that color name. The introductory paragraph in the manual states that this was essentially a "return" to small screen TV due to increased market demand for personal-portable sets. This is a higher end model as it features illuminated channel dials which is somewhat unusual to see on a 12" set. It also came with it's original Gusdorf stand that was specially designed for this set as it has a little factory clip on the stand to hold the set in place. I appear to be the first to ever have the back off the set. It's low hour and was in a clean home it's entire life and still has all of it's original Motorola tubes. Except for some of the tubes, this set is entirely made up of American components and the tuner used in this set appears to be an interesting Motorola design exclusive to the TS-454. The CRT is EIA code 836 and was by made by Motorola's right hand supplier: National Video Corp. Like most B&W sets, they produce sharp crisp pictures!
This set was built in April, 1965 at the Elgin, IL plant, which was just opened at that time. The Motorola Elgin plant was a short lived operation, so it's nice to have a model that came from there. The Elgin plant was opened up as a feeder plant and also B&W TV production was shifted there (and to the Quincy, IL plant) so that the main plant in Franklin Park could have more space for increased color TV production. After the color TV boom slowed down, Motorola was able to consolidate operations and closed the Elgin plant in 1970. At that time, personal portable B&W TV production was shifted over to their new plant in Taiwan which was the happening thing with most of the domestic manufacturers at that time. Here's the interesting part: Even though Motorola closed down the Elgin plant, they still had plenty of other plants in the Chicago area in 1970, so everyone was given the opportunity to take transfers to other nearby facilities hence no layoffs! So here's a nice little piece of Motorola history...
DSC05293 by drh4683, on Flickr
DSC05299 by drh4683, on Flickr
DSC05297 by drh4683, on Flickr
DSC05303 by drh4683, on Flickr
DSC05304 by drh4683, on Flickr
DSC05313 by drh4683, on Flickr
DSC05310 by drh4683, on Flickr
DSC05316 by drh4683, on Flickr
DSC05319 by drh4683, on Flickr
DSC05364 by drh4683, on Flickr
DSC05362 by drh4683, on Flickr
DSC05363 by drh4683, on Flickr
DSC05275 by drh4683, on Flickr
DSC05266 by drh4683, on Flickr
DSC05271 by drh4683, on Flickr
Old 02-10-2016, 10:34 PM
DSC05272 by drh4683, on Flickr
DSC05273 by drh4683, on Flickr
DSC05274 by drh4683, on Flickr
DSC05280 by drh4683, on Flickr
DSC05286 by drh4683, on Flickr
DSC05287 by drh4683, on Flickr
DSC05288 by drh4683, on Flickr
DSC05289 by drh4683, on Flickr
DSC05291 by drh4683, on Flickr
DSC05292 by drh4683, on Flickr
DSC05344 by drh4683, on Flickr
DSC05360 by drh4683, on Flickr
DSC05359 by drh4683, on Flickr
Old 02-10-2016, 10:54 PM
TUD1 TUD1 is offline
That's a neat little set! It's in spectacular condition!
Old 02-10-2016, 11:14 PM
dishdude's Avatar
dishdude dishdude is offline
Another great find and beautiful pictures. Thanks!
Old 02-11-2016, 06:32 AM
jmetal88 jmetal88 is offline
There's someone at the local "Antique Market" (that's what they call it but it's really just a flea market) selling a set that looks almost exactly like this for ~$50, although I could swear when I looked at it that I saw the GE logo on it. I keep passing it up because I assumed it was solid state and wasn't interested in a solid state set for $50, but if it's actually built like this one, maybe I should give it a second look.
Old 02-11-2016, 10:45 AM
As much as I like Motorola products, I always considered the set as a "Rat's Nest". Wires running all over the place. I worked on a few, but they only needed repair when several years old.
There was a problem with the monopole antenna breaking out of the mounting place, because of the strong spring used and careless handling. IIRC, Motorola parts made a kit that could be used to replace the antenna, without having to replace the entire cabinet front.
I had a larger 15" Cadet for a few years. That model used a voltage doubler power supply and one more stage of IF, a great DXer.
Of course, they antenna was broken out.
Old 02-11-2016, 11:32 AM
Wow, you really did a great job of photographing this set, the colors are so vibrant, and the room setting... It's TV nostalgia art at it's finest.
Old 02-11-2016, 11:51 AM
Doug's pictures, without a doubt, are excellent.
I swear, that the HV rectifier isn't a 1X2, it looks larger. It's been 30 years ago, since I repaired one. I think, the only time they were discarded, was when the CRT got so weak, it couldn't be watched.
Old 02-11-2016, 01:40 PM
Yes, I agree. His photography skills are second-to-none.
Old 02-11-2016, 03:48 PM
Neat set. It reminds me of a similar 12" Zenith I briefly owned.
There is something about orange, and cream color with that side handle that makes me think "this is a toy".
From the mid-1960's to the late 70's there were a lot of tube/hybrid plastic cabinet sets that looked like current or later solid state models....Unless the cabinet openly touts being "solid state", "transistorized", "IC", etc. I always look through the back vents to see if there are any tubes inside...Provided the set has any appealing points to it.
Old 02-12-2016, 01:12 PM
The stand doesn't do a lot for me! It seemed to be more of a gimmick, than practical.
With the handle and antenna as it is, it was intended to be used on a bookshelf.
The Cadet line was discontinued for a short time and was reintroduced a few years later. It was a hybrid using 4 or 5 odd-ball tubes and rather hard to work on. From the Taiwan plant.
Old 02-14-2016, 07:47 PM
Beachboy Beachboy is offline
My first new TV was the 1968 version of the Cadet. At the time, I paid $90 for it, and a solid state version was available for an additional $10 (I'm not sure if the 12" solid state version was called a Cadet model or not). Since I was a high school kid on an allowance, $10 was a lot of money for me, so I went with the tubed version. The set saw daily use through 1985, and was never serviced. The sound went out at that point, but the picture was still good. I ended up giving it away, as I didn't want to put any money into an "obsolete" tube-type B&W TV.
Old 02-14-2016, 07:58 PM
I took another look at it yesterday. It's very hard to see in, but I think it might be tube powered. The case wasn't as similar as I was remembering, though, as it has the handle on the top. I'm still not sure I'm $50 worth of interested in it, though, as it has a really small picture tube and I can't really see myself wanting to watch it that often.
Old 02-14-2016, 09:16 PM
WOW That tv looks perfect ! Like New ! Like he got in his time machine and went back
in time and just picked it up at the store new......... makes me think.....
Doug has a Time Machine ! ! !
Another nice post ! !
Thanks !
Old 02-15-2016, 06:38 PM
TVTim's Avatar
TVTim TVTim is offline
All 82 channels.
