Old 01-12-2016, 09:08 PM
Radiotronman's Avatar
Radiotronman Radiotronman is offline
Ok, after playing with the CRT socket, I've got the filament to light. The screen has not lit up yet. Now onto this problem...
Old 01-12-2016, 09:26 PM
Are you powering it up with the projection CRT? Be sure to keep it pointed away from you because of the X-Ray potential.
if it's in the barrel it should be pretty safe.
Old 01-12-2016, 10:09 PM
Yes, I'm testing it in the barrel, in the cabinet. Trying to figure out why my screen is dark. Undoubtedly a loss in high voltage, but what's causing it?
Old 01-12-2016, 10:36 PM
More often than not it's a lack of horizontal oscillator, I always start there.
Check for HV at the cap of the first HV rectifier (the one connected to the flyback) and see if you can draw an arc to an ungrounded screwdriver (a well insulated screwdriver).
Just hold it near it and you should be able to draw a blue arc about a quarter inch long.
Old 01-13-2016, 10:34 AM
I havea s small blue arc off the 1b3 connected to the flyback. Fm audio comes in loud and clear, but no raster.
Old 01-13-2016, 10:46 AM
Here is the section of the schematic either horizontal osc, output and afc....
Old 01-13-2016, 01:23 PM
If you have an arc at the cap of the 1B3 then you should have some HV, have you tested the 1B3's?
Old 01-13-2016, 05:50 PM
I can measure about 1000v off that particular grid cap. All three 1B3s test good.
Old 01-13-2016, 05:58 PM
Its probably not enough voltage to light the heaters in the HV rectifiers. You. Might still have a problem with the oscillator.
It could just be way off frequency. Or the B+ could be low.
Last edited by Electronic M; 01-13-2016 at 07:16 PM. Reason: to merge duplicate posts
Old 01-14-2016, 03:05 PM
Here's an updated picture of the set back together and on. Fm radio comes in great, but still no picture. Still trying to trace down why...?
Old 01-14-2016, 04:29 PM
Finally got a raster!! I found a 16.5 watt, 2450 ohm bleeder resistor on top of the horizontal output chassis. It was completely open and fed the oscillator circuit, along with the 1B3s. I had a ignite 50 watt adjustable power resistor that I was able to get pretty close. There's still a lot of adjustments to make and it's not as bright as it should be, but finally some encouraging progress!!
Old 01-14-2016, 08:04 PM
After playing with the horizontal frequency, I've got a picture. Getting the horizontal to hold for more than 3 seconds is what I'm battling right now.
Old 01-14-2016, 11:50 PM
kvflyer kvflyer is offline
Looking much better, congratulations! Now, you can pick at the remaining problems one at a time. Good luck.
Old 01-16-2016, 12:16 AM
Forgot I had this original ad. It will be nice displayed next to it and wow, $795!
Old 01-17-2016, 07:35 PM
I'm going to order mica caps for the horizontal hold circuit, should I order ones at 1,2 or 5% tolerance?
