Old 04-01-2005, 09:26 AM
ferninando ferninando is offline
dial cord
Hi folks. Thought I mite try here since you probably know.
Where do you get new dial cord? Is there any substitute like some kind of fishing line?
I have an old stereo receiver that needs a new dial cord.
thanks
Old 04-01-2005, 01:27 PM
ekimetsok's Avatar
ekimetsok ekimetsok is offline
Fishing line is a possibility, or try: http://www.electronicplus.com/conten...dia&subcat=dia
(or)
http://www.radioantiques.com/supplies.html
Mike Koste
Gobs of Knobs
Ambler, PA
Old 04-01-2005, 04:39 PM
merrylander's Avatar
merrylander merrylander is offline
If there is a Michael's craft store in your area pick up some #6 bead stringing cord it makes a perfect dial cord replacement.
Rob
Some people are like Slinkies, not really good for anything. They do bring a smile to your face when you push them down the stairs.
Old 04-01-2005, 07:01 PM
thanks guys, I'll check em out.
Old 04-01-2005, 07:54 PM
Tom Bavis's Avatar
Audiophool
Also try http://www.dialcover.com
Old 04-02-2005, 02:45 AM
Well per merrylanders suggestion, I went to my local mega hobby shop and got a 20yd spool of waxed nylon bead string for $1.40. Just a tad skinnyer than the orig. but is very tough and should do the trick quite nicely. Even if I got to double it, but don't think I'll need to.
thanks again guys.
Old 04-02-2005, 07:41 AM
Fisherdude's Avatar
Fisherdude Fisherdude is offline
The Golden Age of Hi-Fi
Just in case that doesn't work out for you, I'm pretty sure AES also carries replacement dial cord.
I may be growing older, but I refuse to grow up.
Old 04-02-2005, 07:45 AM
Sam
Guest
Posts: n/a
real dial cord
thanks again guys.
Hopefuly, the hobbyshop string works, but in my experience there is no substitute for genuine dial string. Hence, I've avoided grief over time by not trying otherwise. Let us know how it goes.
Old 04-02-2005, 07:54 AM
The reason I use the bead string (and it is really very strong) is because I mainly restore vintage receivers and find the "regulation" dial cord used in radios is too thick. I had a length of regular black dial cord and re-strung a Yamaha CR-1020 with it, it simply would not work properly because of the thickness.
Rob
Old 04-02-2005, 08:01 AM
Sam
Guest
Posts: n/a
stringing along
Glad that the stuff works. I'l keep that in mind. Note, however that "regulation" dial string is available in at least two thicknesses.
Old 04-02-2005, 11:59 AM
when I get the stringing diagram and get it all together I'll let ywall know the results.
It's not just 'hobbyshop' string. It's used for stringing beads and is VERY strong and I'm sure will work great. I may beezwax it first to be sure it's 'stiky' around the tunning shaft and pullys just so's it won't slip..
Old 04-02-2005, 04:53 PM
jcmjrt's Avatar
jcmjrt jcmjrt is offline
AK Member
Hey, good idea on the bead string. My Fisher needs that too so I'm going to give it a try. Thanks.
Old 04-07-2005, 09:40 AM
the 1st bead string didn't work out too well so got some more, waxed and abit thicker from a craft store, after hitting an old electronics parts store that no longer gets dial cord, the GC brand. The waxed stuff was easier to work with and I got it all strung and it works fine.
Old 04-08-2005, 09:59 AM
xwarp's Avatar
xwarp xwarp is offline
AK Member
nylon kite string.
