Old 11-12-2015, 04:36 PM
Often you can hear a faint buzz coming from the V.out transformer and/or yoke windings. If you can hear it, try turning the V.hold control stop-to-stop, and you'll hear the buzz change in pitch. The pitch change will usually tell you whether the osc. is running too fast or too slow.
This in turn can be a troubleshooting guide.
Old 11-12-2015, 11:19 PM
Radiotronman's Avatar
Radiotronman Radiotronman is offline
Success!
I replaced a few more out of tolerance resistors in the vertical oscillator circuit with little improvement. So I went to my 1950s tv repair bookshelf for some pictorial help. My book said split vertical picture is due to a few things, including misadjusted vertical hold control. I laughed and thought....no kidding! But I figured nothing else has worked and I didn't really spray this control. I rocked it quickly from one end to another and bingo, one picture!
Old 11-12-2015, 11:33 PM
Booyah! Say hey!
Old 11-13-2015, 12:32 AM
EdKozk2 EdKozk2 is offline
Tinker
Picture looks nice.
Old 11-13-2015, 10:49 AM
Nice, but a little odd. The image should be rectangular - not fill the screen. Something more like this. I wonder if the yoke is not pushed all the way forward or the HV is too low ?
Old 11-13-2015, 12:38 PM
Nice, but a little odd. The image should be rectangular - not fill the screen... I wonder if the yoke is not pushed all the way forward...
Wouldn't that cause a neck shadow?
Old 11-13-2015, 01:39 PM
The last picture does have what looks like a neck shadow (I see a dark ring around the picture on the CRT face). Also, adjusting the height and vertical linearity for a "full screen" raster on a round CRT can itself cause the vertical-hold control range to be less than ideal. (Except on a round-bezel Zenith, of course.)
Old 11-13-2015, 01:47 PM
What kind of signal source is used? With my Zenith DTV convertor, I can get a small squared screen on some channels. With the caption, "set by program".
Old 11-13-2015, 02:04 PM
Over the air low power NTSC. We still have LPTV channel 6 in Chicago.
Old 11-13-2015, 07:08 PM
The darkness around mine is because I haven't perfectly adjusted the yoke and focus coil. I will do that when I get it ready to finally put back in the case. Getting the adjustable mounts at the proper depths will also help the centering.
Old 11-14-2015, 12:11 AM
Restoration complete
Got it all back together....time to watch tv!
Old 11-14-2015, 12:44 AM
Do you always watch TV sideways?
Old 11-14-2015, 01:04 AM
Arcanine's Avatar
Arcanine Arcanine is offline
I can only hear the audio from them here. Decently I might add, but even on a huge TV Beam aimed at Chicago I can't see their picture.
A couple times when conditions were exceptional and beyond good conditions for FM propagation, back in the Q87 days, I picked them up in Fon Du Lac Wisconsin, and kept a mostly stable signal all the way back to Lake Geneva.
Was pretty cool.
Old 11-14-2015, 12:42 PM
I noticed that too. If he is using a Windows machine to upload, then he should use windows photo viewer to check for rotated photos, and use it's rotate 90 degrees buttons to get the pictures right side up prior to upload.....
Old 11-14-2015, 06:41 PM
Boobtubeman's Avatar
<---WANTED: Motorola 17P6
Perhaps its in front of a couch and he likes to watch tv laying on his side?
SR
