Old 09-12-2015, 01:17 AM
GE 12T1 CL find
Kept telling myself no, no, I'm not going to go look at this... well, it's in my Kitchen now.
It was only 30 miles away and looked clean so I took a drive over with my CRT checker, rule is, no more sets with bad CRT's.
It started out looking bad so I turned it up to 8 volts for about 60 seconds, it gradually climbed well into the good range so I turned it off for a bit then retested it at normal voltage, it still checked great, dropped it down to about 5 volts and it still held good so I bought the set. When I got home I tested the CRT one more time, it went way into the good range in just the time it took to set up the tester!
The drive home sucked due to construction, an hour to go two miles!
When I got here I tried the set on the Variac and got some static from the speaker but noticed the 6BG6 and a few other tubes weren't lighting.
I recalled that this chassis has a split series heater string so I went looking for missing tubes and found the Damper and 1B3 were gone, replaced those and the heaters all lit but I still got nothing, and it started to smell hot so I shut it down.
It'll need recapped. I have a complete spare chassis from a console I junked and another from a 10" Locomotive if I need any hard parts, but that's a ways down the road, lots of other projects ahead of it.
It's missing the back, anyone have a spare hanging around? or a picture of what it looks like, metal, hardboard?
GE sure liked Brass back then!
Old 09-12-2015, 07:55 AM
Doug66 Doug66 is offline
I wonder why back are so often missing? I've heard its because repairmen failed to put the backs on the sets after service. If my parents ad taken a set in for repairs, and it as returned with ho back, they would have raised heck with the repair shop.
Old 09-12-2015, 08:29 AM
Olorin67 Olorin67 is offline
I dont think professional repairmen would lose the back... besides they would not want the liability of someones kid or cat getting electrocuted. A lot of people back then would take the tubes out, and run down to the drugstore to use the self service tube checker when their set went out. then either they would decide the set wasn't worth the investment if expensive tubes were bad.. or they would buy a tube and that still didn't fix the problem...and chuck the set in the attic or basement..and the back never got put back on and eventually got lost.
Old 09-12-2015, 09:20 AM
tvcollector's Avatar
I love that style.. I'm glad you got it.. If I were local to it, I would have jumped on it.. It's something not too big... Glad the CRT woke up like it did..
Old 09-12-2015, 09:45 AM
The GE table models had Masonite backs, the consoles seemed to have both, depending on the year.
Old 09-13-2015, 09:19 AM
edison64's Avatar
edison64 edison64 is offline
THE A-1 WIRELESS MAN
Location: NW INDIANA THE MAPLE CITY LA PORTE (GO SLICERS)
The missing back question puzzled me for many years, until I started asking around, a lot of the older people that I talk to, stated that they knew someone who worked on TVs or radios or electrical stuff, and they always took their stuff there because the repair shops cost too much money. Back in the day there were literally tens of thousands of men and women trained by the US government for electronic assembly and repair due to World War 2. So there you have it missing back or simply not put on by amateur repair people who saw them more as a pain in the butt than anything else. So much different than today when you simply just throw it away if it quits, because no one knows how to repair anything and nothing is made to be repaired... Even trying to buy modules to swap out in the flat panels is cost prohibitive. I would think someone could make a pretty good money in the niche market for making reproduction TV and radio backs.
RCA VICTOR and its dealers bring you......
Old 09-13-2015, 12:43 PM
Gregb Gregb is offline
There are a couple places that do repo backs but not a lot of TV backs.
Gregb
Old 09-13-2015, 07:19 PM
Radiotronman's Avatar
Radiotronman Radiotronman is offline
I have the same set with its back. I got mine from a TV repairman that passed away. Below is the picture of the back. It is hardboard with a tube layout glued to it.
Old 09-13-2015, 07:36 PM
Thank you for the picture, it looks like it would be pretty easy to make something passable.
Old 09-14-2015, 06:32 AM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
Either that, or people just assumed that the set would run cooler with more ventilation. Probably true, considering these things were sometimes run from breakfast till bedtime.
Old 09-14-2015, 02:07 PM
I agree that ventilation and the fact that they often needed service made it pretty tempting to leave the back off. And back then people seemed to have better common sense about not sticking their hands inside of glowing electrical appliances.
Old 09-14-2015, 02:26 PM
I think at least in some cases the back was removed for servicing when the set quit, if it wasn't repaired quickly it probably got stuck in a closet or basement and eventually they got separated from the set and lost.
Old 09-14-2015, 08:11 PM
decojoe67's Avatar
That's a rather uncommon GE. Very nice find.
I've been collecting vintage TV's for decades and many from the early post-war era have their backs missing. I read that in these early days magazine articles told TV owner to leave them off for better cooling. Once they were separated from the set, that was it.
I've made some nice backs with perforated, fairly heavy gauge steel stock using metal sheers, a dremel, and a grinding wheel. It's not east to work with, but they look very convincing if done neatly and cleanly. You can find the stock on eBay.
Old 09-17-2015, 04:33 PM
http://milwaukee.craigslist.org/atq/5196773746.html
Isn't this the same model? Hopefully someone has already snatched it.
Old 09-17-2015, 08:03 PM
decojoe67's Avatar
That is the same model. In fair as-found condition like that, with a good CRT, it's not worth much more than that. The problem I see with that one right off is the wear on the left side reverse painted front glass plate. That's can be a difficult fix even when done skillfully. It stands-out in the pic and will likely look worse in person. It's finish is badly flaking too and will need a refinish.
