Old 08-05-2015, 08:19 PM
DavGoodlin's Avatar
Motorola Minion
Stromberg Carlson 435-M Labyrinth
When it rains it pours, especially with local CL ads for antique radios.
This model is not pictured in Radioatticarchives, so I figure it may be less common. The amplifier is PP 6V6 tubes, similar to GE sets of 1940.
It has both AM and SW with preset pushbuttons on one chassis plus a second
chassis for the pre-1948 FM band that is 42-50 Mc
The real interesting part is the cardboard tuned ports for the speaker.
This claims, in an advertisement, to block all unwanted sounds from coming out the front.
Also got a nice Philco 37-9 and a chassis from a Majestic 92 (which is a Grigsby Grunow 90B)
-Dave G
Old 08-21-2015, 01:56 PM
Tom Bavis's Avatar
Audiophool
You'll find the Stromberg Service data on my website: http://audiophool.com/MadeInRoch.html
Old 09-03-2015, 05:20 PM
RJMiranda RJMiranda is offline
Cardboard labyrinth
The labyrinth concept is OK and very interesting for a radio of that era. It should have been a "selling point".
But cardboard and any easily-vibrating material is bad for anything acoustic. It colours the sound by absorbing some frequencies and reinforcing others, and thus the frequency response has peaks at the fundamentals and harmonics of every piece of vibrating surface in the speaker enclosure.
That said, I wolud not be very surprised if the set had a very pleasant sound. Acoustics is a very subjective subject. And the theories on the physics books work much better in the books than in the real life.
Good luck with your new-old radio!!
Old 09-03-2015, 06:34 PM
Some Bose radios use labyrinths made of plastic. The same plastic piece that forms the cabinet. May or may not be "hifi"...
Old 09-04-2015, 08:06 AM
Labyrinths were used in a lot of medium-level equipment with smaller-than ideal speaker enclosures, to try and make them give a better bass.
But it was a surprise to me seeing one in a vintage radio. Maybe I am not so old, after all.
Soviet-made Elektronika stereo record players of the ´80 vintage had plastic labyrinths inside the speaker enclosures. I saw one once and the labyrinth was not even fixed to the cabinet. Nice noises it made.
The one I saw was junk, so maybe it came from the factory correctly fixed to the enclosure, and later someone opened the enclosure, unscrewed the labyrinth and ended with some "extra" screws.
Old 09-04-2015, 12:21 PM
That's similar to my 440-M, which also had the acoustical labyrinth. You can read about that radio, with a link to the labyrinth patent, in this article:
http://antiqueradio.org/StrombergCarlson440M.htm
Phil Nelson
Phil's Old Radios
Old 09-05-2015, 10:09 AM
Phil Nelson
Phil's Old Radios
Most of those sets came through with the wide radio-phono cabinet, much less desirable.
