Old 06-23-2015, 09:41 PM
Telecruiser's Avatar
Telecruiser Telecruiser is offline
Back in the 1960's when many of these sets came in for service, we just lifted one lead of the selenium and placed a diode in the circuit. The voltage would go up a little, but nothing alarming. It worked then, I don't see why it wouldn't work OK now. Remember the tolerances on most consumer TV's is about 20%.
Old 12-29-2016, 03:49 PM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
So to resurrect this discussion, if you use a ballast like this one AND have diodes in place of the seleniums, is a dropping resistor required?
The set's running fine, but that 30 ohm resistor starts to smoke after about a minute.....
Old 12-29-2016, 04:48 PM
I have diodes in place in 3 of these sets I have and I have a 50 ohm 10 watt resistor in place of the 37 ohm and it's good.
Old 12-29-2016, 07:46 PM
Kamakiri's Avatar
Aha! Thanks! I'm a bust out the soldering iron
Old 12-29-2016, 07:54 PM
The 10 watt does get hot but it is a ballast and this resistor does hold up.
Old 12-30-2016, 11:38 AM
Kamakiri's Avatar
I was gonna say.....that resistor is getting mighty toasty, but it is holding.
Old 12-30-2016, 06:17 PM
Well we really don't know what the actual wattage is for each resistor within the ballast itself so maybe a 15 watt would run Alittle cooler. I have had my 3 sets with that resistor in there since they were done and not one ever opened, lol , not yet.
Old 12-30-2016, 06:22 PM
Measure the voltage drop across it. Watts = (V * V) / R. A good rule of thumb is to use a resistor rated for at least twice the power it dissipates.
Old 12-31-2016, 11:27 AM
Keep in mind that heat dissipation is all about surface area and air flow over that surface. Some modern day components are rated for higher wattage simply because the materials used can handle the heat, but that alone will not keep them cooler. Resistors for example have gotten smaller for the same wattage rating.
