Old 04-22-2014, 11:43 PM
tvcollector's Avatar
Sony Betamax SL-2300
I just got one of these locally fairly cheap.. It's got the common tracking lines and flutter problem.. I did a research and from what I found, it seems the common problems on these are the tracking pot.. I did measure with my ohm meter and it reads pretty much the same when adjusting the control.. I don't have the service manual for this unit yet, so I don't know the values.. I did try to find a replacement part, and didn't have any luck.. So I don't know if this is something I could just get from Mouser or Digikey once I find out the specs, or if it's a part that was made for the unit and not any on board pot control would fit.. Maybe someone here knows a quick fix?
Old 04-23-2014, 05:55 AM
tvtimeisfun tvtimeisfun is offline
Hello these model of beta vcr are also known to have problems in the servo circuit with bad caps check those first before ordering any parts also a quick fix is to adjust the capscan speed...
Old 05-14-2015, 06:26 PM
djfivos djfivos is offline
Yeah...bad capacitors in the servo!
