Old 02-19-2015, 09:05 AM
oldtvman's Avatar
oldtvman oldtvman is offline
Larry Melton (oldtvman)
During my years of tv service I never saw a Motorola 23" that had a good picture. Not until Mashushita took over the Motorola name.
[IMG]
Old 02-19-2015, 09:39 AM
They only took over the Quasar name. They also had the Franklin Park and possibly the Taiwan plant.
Old 02-19-2015, 09:43 AM
Yeah, from what I've red here I'd estimate the number of good 23EGP22s known to exist at around 10.
Make that nine. I regret to say, I bought one last fall, that went to air before I received it.
Old 02-19-2015, 10:14 AM
a few pics...
Old 02-19-2015, 10:29 AM
I wonder if after that tv is fixed, running it at just above minimum bearable brightness
and possibly adding a 2 to 3 ohm 10 watt resistor in series with the picture tube
filaments - reducing the voltage 2 to 3 volts may just add several years to the
life of a 23EGP22.......?
It sure looks like a nice bright tube now....
Old 02-19-2015, 06:47 PM
The CRT was designed to operate on 6.3 volts. I don't think, running it on a lower heater voltage, would extend the life of the CRT.
That CRT, like the mid-90's Zenith CRT's were just a bad situation. It was all, the luck of the draw.
In the mid-60's, when rectangular CRT's got popular, there was common failures in the other manufactures CRT's. I saw bad CRT's in Zenith's, RCA's and Sylvania's, where the sets were only 14 to 18 months old.
Guess what, the set owner, had to pick up the tab for a CRT replacement.
A little later on, most manufacturer's increased the warrantee to two or three years.
Old 02-19-2015, 07:26 PM
oh so maybe the 23egp22 i have in there now is a much better one since it has a date of december 1980. but even a 10 year warranty would be up by now, lol lol
Old 02-19-2015, 07:36 PM
Odds are it's a rebuild, and probably a LOT better off in terms of reliability because of that rebuild...
IIRC the electron guns in the EGP were essentially the same as those in other tubes, but the early EGP cathodes did not last as long as they should...So a rebuild with better made cathodes should be every bit as good as a properly made non-EGP.
Old 02-20-2015, 10:45 AM
Here, I thought that the 23EGP22, I bought was a real gem. Rebuilt by Video Display Corp in the mid-80's, with a 2 year warranty on it. It's even a rare-earth.
I thought to myself, This set's going to have a great picture. I checked the tube before installing it. Zip, nutin, nada, not even a heater glow. I even started it at a lower heater voltage. Looked like it went to air, but no white on the getters.
When sent, it was packed very well and shipped by Fed-Ex. Both boxes were in good condition, so it didn't appear to be mishandled.
I don't think the tube was checked before it was shipped.
Old 02-20-2015, 12:01 PM
I still have a VDC 23vecp22 in the box, have not checke it BUT I did recently install one that a got a couple years ago into a zenith.
has a purity issue that can not be worked out. you can see it with the hand held degausser as what looks like a pinch or some other defect in the shadow mask in one corner the other issue is some purity in the top middle that shows like a purple stain. Its more noticeable on some background colors that others.
I have another on from VDC in the box, maybe someday I will try it out. Too bad since both test great with emissions and cutoff.
My guess is one of them took a hit to the corner, maybe jacked the shadow mask up. I hope the other one in the box is ok.
Old 02-20-2015, 12:13 PM
If the getthers are still normal, then perhaps it is just a bad heater weld. I'd consider getting something like a charged 80uF 200V cap connecting it to the heater pins and tapping on the neck with a screw driver....You have nothing to loose in it's current state.
Old 02-20-2015, 06:04 PM
Well My 23EG was deep green in the face, Timmy's set looks like one of those grey
face tubes common in the 80's... Maybe his was not a rebuild, but a new one....
Maybe he has nothing to worry about.... One of you guys who knows more maybe can
tell more with the manufacturer code....? But then he's most likely gotta remove the
metal shield around it, maybe better leaving it alone.... Timmy, Don't go digging in there!
Old 02-20-2015, 08:22 PM
When I first checked it with a reduced heater voltage, the neck got a little warm to the touch, but I couldn't see any glow.
I'll try the charged cap trick, as the Crt is probably scrap.
When I first received the tube, it had a lot of gray plastic tape wrapped around the front of the tube, but not covering the bond between the CRT front and the safety glass. It was appearant the the tube needed cataract surgery. I didn't care about that, as long as it showed a good picture.
A little history about this set. I bought it from Doug, drh**** on Ebay.
The set is a low hours set, that is extremely nice and appears to not ever being repaired. All original tubes, clean inside and out. That was the famous CRT that almost cost him his life. It imploded, when he was attempting cataract surgery.
I bought a conversion kit on ebay for a 25XP22 and half the parts were missing. I guess some things aren't meant to be.
Old 02-20-2015, 09:27 PM
I'd make sure the heater is open first. If not all the cap trick will do is possibly risk damaging the heaters....Though if it is down to air and the neck is getting warm because the heaters are warming the air inside, it won't make any difference if the heaters get damaged since that is the point where only a rebuild may help.
Old 02-20-2015, 09:58 PM
EM is right, if the tube is getting warm, then the heaters are not open....
The charged cap will just melt them right off....
You should carefully check to see what you have going on.... Check voltage and current
going to the heaters, use 4v DC if you have to, be sure they are actually good.
