Old 05-13-2014, 03:15 PM
another great job Bob. Now on to the Princess!
Old 05-31-2014, 12:27 AM
Not so fast!
First off, I got a new tripod and better lighting on my workbench
Next, I wasn't really happy with having the electrolytics scattered around the chassis. So I found an old cap of the proper size, restuffed it and restored the original wiring.
I also added another 10 ohms to the filament dropped to compensate with the higher line voltages encountered today.
I also rebuilt the old dual diode assembly with modern diodes.
Then the "fun" process of installing the chassis. Remember I was just sent the chassis. The cabinet and CRT are from my set.
It played fine for a few minutes then the horizontal collapsed to a vertical line then disappeared altogether The sound is still good though.
I pulled the chassis back out and wiggled some wires. That seemed to fixed the problem at first, but after about 30 seconds it collapsed again. I pulled the chassis twice more with the same result.
So it seems to be an issue with a loose yoke connection or possibly over heating. I'm not so sure about heat though because once the problem occurs, letting the set cool down does not help.
Old 06-05-2014, 05:44 PM
It was a pain to pull the set apart again, but I think I found the problem.
When the picture goes out, it collapses to a vertical line then quickly fades away. So I figure it must be an issue with the horizontal circuit.
Sure enough. A scope confirms that although the hor. oscillator is running just fine, there's no signal on the 12DQ6 HOT grid.
After a little poling around, I discovered that putting slight pressure on the K5 hor, network in just the right spot restores the raster. I figure there's a cracked PCB trace or bad solder joint under that network.
I wedged a bit of foam against the network and the sets has been running fine for a bout 30 minutes now. Next, I'll pull the board out and fix it properly.
Old 06-05-2014, 06:47 PM
When I restored my Siesta, I found the plastic cap from a Bic pen wedged tightly between the main board and the chassis. At the time, I wondered whether it fell there by accident or it was purposely stuck there to "fix" an intermittent connection on the board. The TV worked fine after I redid the board, anyhow.
Phil Nelson
Phil's Old Radios
Old 06-06-2014, 03:14 AM
It helps if you remember to actually solder the leads
Old 06-06-2014, 07:30 AM
I know this already but sometimes forget and then have to "re remember", but I am adding to my check list is a good magnifying glass and strong light, and just go over the pcb/wiring as part of my normal check out.
Old 06-06-2014, 10:52 AM
I recently added some Xenon under cabinet "puck" lights. They get kinda hot but do kick out a lot of light and they're cheap
Old 06-06-2014, 11:24 AM
NoPegs's Avatar
NoPegs NoPegs is offline
The glass is -3dB.
Based on his performance of the miracle of healing upon a severely stricken chassis, I believe Bob should be canonized henceforth as Saint Predictia IV.
Old 06-06-2014, 09:51 PM
Well I don't know about all that I still have several Predictas to restored so we'll see.
I soldered up that open joint and reinstalled the board. The task was made easier because I happened to have another 9L37 chassis nearby for reference.
Viola! It works and has been running for 30 minutes without any more problems popping up
Old 06-08-2014, 12:41 PM
ed857 ed857 is offline
Bob,
Would you be interested in selling the round bezel + dial glass from your extra RCA 222 cabinet?
I sent you a email.
Thanks
Old 06-09-2014, 02:33 PM
Notimetolooz's Avatar
[/QUOTE]
That's a nice bench setup, Bob.
Tim
Old 10-16-2014, 03:06 PM
I recently received this photo from the owner showing the restored Predicta running in his office
Old 10-17-2014, 04:21 AM
Down Under's Avatar
Down Under Down Under is offline
Looks great, but I definitely prefer the factory stand.
Four Predictas down, now to score a Continental.
Old 10-17-2014, 10:40 AM
Hopefully he doesn't leave that test pattern on all the time.
