Old 09-30-2014, 09:26 AM
ctc197cd schematic
hi all, does anyone have a schematic for the ctc197cd or just ctc197 both should be the same. im looking for the specs on a diode near the flyback but didnt take the back off again to get the location number but ill know it if i seen a schematic. thanks
Old 10-01-2014, 05:42 PM
Gunslinger Gunslinger is offline
I have it on micrfische. Give me the part designaation and I'll give you the part number
Old 10-02-2014, 01:14 PM
Findm-Keepm's Avatar
Followin' the Rules...
Complete parts list for the CTC197CD attached. Text searchable, just search for the reference designation (CRXXXX).
Brian
USN RET 22YRS (Avionics/Cal)
Old 10-02-2014, 07:44 PM
ok, great thank you much
Old 10-02-2014, 07:47 PM
the location of the diode i need on the board is cr14701 but i dont know the electrical specs i got a sub in it now it works but i dont know what the right one is. looks like a stock number for that diode is 241304.
Old 10-02-2014, 09:03 PM
will look on the schematic tomorrow and see what I can up with.
Old 10-03-2014, 06:34 AM
ok thanks
well i came up with this diode weather or not its true but i found that this diode is supposed to be a 200 volt 1 amp. problem is the sub diode i put in had a 400v 3amp 150ns rating but it left me with a intermittent dark line on the lower left screen. so i changed the diode to a 200v 3amp 35ns diode and the dark line is 95% gone but shows up very small from time to time. so if infact the right diode that goes in has to be a 200v 1amp thats ok but i am wondering what the recovery time is in, ns . the diode that had came out had blue lettering and i had researched it but never found a thing on it so there may be special characteristics to this diode even though its not marked with an X to indicate anything special. if memory serves when this diode first went bad i think i tried a 600v 1amp general purpose diode and it burned , maybe the recovery time was not consistent with what the set needs.
Old 10-03-2014, 10:19 AM
For two bucks, I'd go with the original. Thomson used some funky diodes, most are low forward drop, high speed, from either Sanken, Toshiba or Fagor. You could go through 20 replacements before you found one that would work, so we kept a small stock of original diodes on hand.
I checked my stock, I don't have anything that new, and I don't think my junk M134 chassis used that diode.
Cheers,
Brian
Old 10-03-2014, 11:02 AM
do you know the specs for that diode?
Old 10-03-2014, 12:11 PM
No, I don't. Even with specs, you're gonna buy a replacement, right? Why not spring a couple of dollars for the original replacement, and not worry about specs. With RCA semiconductors (like Sony), originals are always the best way to go.
Brian
Old 10-03-2014, 02:52 PM
yup thats what it will be, why not after all its 18 years old and plays like it did when new after of course several flybacks and other repairs,lol thanks
