Old 05-20-2014, 11:48 AM
IsthmusTV's Avatar
Blonde Andrea T-VK12
Greetings,
I picked this up locally for the princely sum of $43. Overall it's in excellent condition. I've never seen one of these around here, let alone a blonde version. Attached are some pictures from the seller. I got it safely home and the dial glass is still intact. This is my first TV with channel one!
Old 05-20-2014, 11:58 AM
IsthmusTV's Avatar
I haven't had much spare time lately, but I did give it the once-over and checked the CRT, which I believe is a 12QP4. There is no type marked on the base, so I'll have to confirm the type later. The emissions were a little sleepy at first, but after a 10 minute cook it came right up. Cut off is good, too.
Here's a first look with the back off:
Testing the CRT:
After a 10 minute cook at 6.3V:
I'm really excited about restoring this set! The only issue I see is some flaking paint on the back side of the dial glass. Fortunately, it's just plain dark brown paint and not any of the logo or other lettering.
-Clark
Old 05-20-2014, 12:14 PM
DavGoodlin's Avatar
Motorola Minion
Very Cool! I really like that dial, everything but SW.
Is that about 1947? it has channel one
-Dave G
Old 05-20-2014, 01:18 PM
IsthmusTV's Avatar
Thanks! I think it's officially a 1948 model, so it must be one of the last with channel "1".
Old 05-20-2014, 02:56 PM
$43 ?!? I'll give ya $86 !!! Double yer Money...(grin) Seriously, that is a GREAT score !
Old 05-20-2014, 08:22 PM
M3-SRT8's Avatar
M3-SRT8 M3-SRT8 is offline
Nice set. Very nice set. I have one in mahogany and it is a good performer.
Good luck with the restoration.
Old 05-20-2014, 08:40 PM
Steve D.'s Avatar
Steve D. Steve D. is offline
Beautiful condition. Nice find. I believe this model was called "The Sharon." BTVK-12. The B is for blonde finish.
Left photo courtesy: TV History site.
-Steve D.
Old 05-21-2014, 02:45 PM
IsthmusTV's Avatar
Thanks, Lee. I remember following your restoration on ARF. It's one of the things that drew me to this set when I saw it.
And Steve, thanks for letting me know that this blonde has a name. I'll take very good care of "Sharon"
With family and work commitments, it may be a month or two before I can't start the restoration in earnest.
-Clark
Old 05-21-2014, 02:57 PM
Wow, Clark. That looks Really nice.
Old 05-21-2014, 07:49 PM
ggregg's Avatar
ggregg ggregg is offline
Nice Carl! Love that set.
Old 05-21-2014, 08:48 PM
EdKozk2 EdKozk2 is offline
Tinker
Hi Clark,
Cool set, I like that tuner arrangement. Is it a continuous tuning type tv station selector or does it use a low band / high band switch ?
Ed
Old 05-21-2014, 11:35 PM
Dave A's Avatar
Dave A Dave A is offline
It looks like an Inductuner I have in my Sightmaster which also shows an AM band. I forget if it actually receives AM.
Old 05-22-2014, 09:33 AM
IsthmusTV's Avatar
It is a Mallory InducTuner or InpuTuner with continuous tuning and no high/low TV band switch. There is a four position function switch to select phono, AM, FM and TV. The AM tuner section is an integral part of the main chassis, and shares one of the TV sound's IF amplifiers (at 455 kHz). From what I can tell looking at the schematic from SAMS, putting the selector switch in any position other than TV kills the B-plus to the sweep circuits and may also turn off the CRT filament (I need to print out the schematic and get a better look).
The good news is that the continuous tuner is not frozen and actually tunes without much effort. So I think that the delicate ceramic shaft must be OK. I don't want to mess with it much until I've had a chance to check it closely and carefully clean and re-lube as necessary.
Old 09-20-2014, 04:12 PM
IsthmusTV's Avatar
I finally had some time to start working on this set. The chassis is cleaning up very nicely with no corrosion what so ever.
It was a little tricky to remove the CRT because the the foam rubber cushions had turned to glue. When I finally got it out, I was surprised to learn that it's a 12JP4. From all indications, this is the original tube, but the SAMS for this set specifies a 12QP4. The 12JP4 is a 50 degree tube that's not aluminized, yet it has a straight gun and needs no ion trap. I hope that it doesn't have an ion burn! It woke up nicely with good emissions. The tube is a DuMont. Anyone know what the silver "T" stamp means?
The chassis looks totally untouched. Just the way I like them Most of the tubes appear to be the original Sylvania and RCA's with 1948 date codes.
Instead of black beauties, this set if filled with Grey Tigers
While the precious dial glass is intact, just the brown paint on the back side is flaking off. Fortunately, all the important markings are OK:
I'm not sure I dare mess with trying to replace the flaking paint. I may consider putting some brown paper behind the glass, just so the pilot lights don't shine through.
-Clark
Old 09-20-2014, 06:38 PM
Gregb Gregb is offline
WOW Clark, I must say that is one super clean set. Good luck with the resto, it will be a great set when done.
Gregb
